Coordinates of CoM
Hi Soeren,
I build a new model for the arm movement where I use the new files you
uploaded. Now I want to scale another model to the AnyBody size and
therefore I look for exact coordinates again. Normally no problem but
in this model there are difficulties: for the humerus segment I need
the origin, the joint coordinates and the CoM coordinates. When I
click through the window next to the texteditor I get the values for
the origin, but I don´t find the definition of this origin. But that´s
not my problem. The joint coordinates were easy to find, after a
kinematic analysis I got nice values.
But now my question:
The variable “sCoM” is defined in relative coordinates. When I want to
know the absolute coordinates I define a RefNode with the same
coordinates like sCoM and after loading and running a kinematic
analysis again I can click in the window next to the text editor to
get “r”. I tried it for the Humerus segment but the absolute values
for this sCoM node doesn´t fit with the origin+relative coordinates.
I definied it like this:
sCoM={0,-0.18Length,0}; //given by the model
AnyRefNode show_sCOM= //defined by myself
sRel = {0,-0.18
.Length,0};
AnyDrawRefFrame sCOM=
RGB = {1,0,0}; //rot
ScaleXYZ = {0.3, 0.3, 0.3};
Here are the values I get for r, sCoM and abs. sCoM:
Main.Model.HumanModel.Right.ShoulderArm.Seg.Humerus.r = {0.01868401,
0.4146685, 0.1929215};
Main.Model.HumanModel.Right.ShoulderArm.Seg.Humerus.sCoM = {0,
-0.06120846, 0};
In my opinion this has to give the absolute coordinates for sCoM:
(0.01868401, 0.35346004, 0.1929215) > x and z were the same as before!
But AnyBody calculates:
ain.Model.HumanModel.Right.ShoulderArm.Seg.Humerus.show_sCOM.r =
{0.02399838, 0.353925, 0.1982561};
Now I´m confused. Where is r for the humerus segment defined? Which
coordinate system is sCoM defined relative to? What does the AnyVec3
Offset mean? ( I uploaded the model named Armmodell04) Does this
Offset influence the coordinates of sCoM? What´s his job? How do I
have to calculate if I want to know the absolute coordinates of the
CoM? I hope you can solve my confusion.
Thank you very much and with best regards, Maren
Hi Maren
Your assumption of the expected position of Show_sCom to be
is only correct if the local cooridnate system of the humerus
segment is 100% alligned with the global ref system, if this is the
case then your are right. In the present case the orientation of
humerus segment is slightly out of allignment so a translation of -
0.061 along the local y axis of the segment will also produce a
small movememt in the global x and z coordinates because the axes
are not alligned. I think this is why you do not get the constant x
and z values you expected.
The Offset value has been used to translate the nodes of the segment
by a certain amount, i do not think it will have any influence here.
So to summarize:
sCom is given in the local coordinate system of the segment
You can find the r value of Com as the r vector of the Show_Com node
I hope this made it more clear, otherwise please do not hesitate to
write again.
> Hi Soeren,
you
but
need
for
that´s
want to
coordinates.
> sRel = {0,-0.18
.Length,0};
{0.01868401,
> -0.06120846, 0};
before!
AnyVec3
