the possibility in the AnyBody models to “deactivate” parts which are not in the region of interest is very helpful.
But wouldn’t it be more straightforward if muscles (no matter if physically existing or just auxiliary) belonging to these “deactivated” parts do NOT contribute to the muscle recruitment? Is the strength of these auxiliary muscles physically reliable?
It would be nice if there was a switch which allows for removing thoses muscles from the recruitment algorithm (e. g. with an internally chosen very high strength).
sorry, i did not find your suggestion to replace those muscles by AnyReacForce. This method would require that one is aware of this problem and it would require to know which are the muscles to be replaced.
I deactivated some parts of the model and was surprised that these parts still influence my results. My suggestion was born as other users may also drop this brick.
I used a workaround by increasing the muscles’ strenghts, as you also suggested in my other thread, i. e. the problem is solved for the time being.
My wish was thought to avoid this problem in future as it is easy to overlock these auxiliary muscles.
