I encountered to define my desire outputs!!!
how can I define a particular output in script?for instance,I tried to
define ForceonForcePlate1.Fout like this:
AnyOutputFile OutFile1 = {
FileName = “out1.csv”;
AnyForce ForceL= Model.Environment.ForceOnForcePlate1.Fout;
and many combination of them.but I could not!
and in tutorial is not a special part to how to define output.
The output value you want(Model.Environment.ForceOnForcePlate1.Fout)
is a vector. So when you define the output you must use an AnyVector
instead of AnyForce.
Just modify the script this way:
— In anyscript@yahoogroups.com, j.arabneydi@… wrote:
> Hi,
tried to
> Jalal.Arabneydi
> Best regards
