How to apply a constant force along a spring connected between two nodes?
Hi @NissyElan and welcome to the forum!
You can define forces in AnyBody using a force class such as the AnyForce3D
Here is an example of a constant force defined in the local coordinates of the target object.
AnyForce3D AppliedForce = {
Flocal = {100, 0.0, 0.0};
AnyRefFrame &obj = TargetObject;
You can also make the force depent on some measure:
AnyKinLinear &MyMeasure = Path.to.some.measure;
F = {100 * MyMeasure.Pos, 0.0, 0.0};
Using the F variable instead of the Flocal expresses the force in global coordinates.
Bjørn
Thank you Sir for your response
