Driven by markers
Good afternoon,
I am trying to drive the StandingModel (full body) using markers. As a
guide, I use the Gait3D model and the Gait webcast presentation. Here is my
question:
In the presentation, the green arrows correspond to the last constraint, the
SacrumZ. The equation used is RAsisZ + LAsisZ = SacrumZ. According to the
figure in p.10 of the presentation, the Z axis is vertical. Therefore, it
would mean that the height of the sacrum needs to be twice the average
height of the Asis. What am I not getting right?
Jean-Olivier
LIO - CHUM
Hi Jean-Oliver
RAsisZ is a measure in the z direction betwen the right Asis marker on the model
and the free floating makrer
LAsisZ is a measure in the z direction betwen the Left Asis marker on the model
SacrumZ is a measure in the z direction betwen the Sacrum marker on the model
So the equation RAsisZ + LAsisZ = SacrumZ means that distance measured in the z
direction between the human marker and the free floating asis markers needs to
add up to be exact the error on the sacrum marker measured in z. So what we are
trying to do is to distribute the error between the three markers. It do not
mean that " the height of the sacrum needs to be twice the average height of
the Asis" it means that distances measured in the z direction between the model
markers and the free floating markers needs to be that be given according to the
equation.
It sounds as an interesting model you are building here are some advices:
Try to keep having a running model by using joint drivers on most joints and
then gradually one by one replace those by marker drivers.
Switch off the muscles when you play around with the kinematics, this can be
done from the main file.
Always keep a exact count on the number of drivers you add to the model and
remove, this number should never change, for the same body model.
Please do not hesitate to write agian if you have further questions.
AnyBody Support
— In anyscript@yahoogroups.com, “Jean-Olivier Racine”
<jean-olivier.racine.1@e…> wrote:
> Good afternoon,
> question:
> Thanks,
> Jean-Olivier
> LIO - CHUM
Hi again,
I do have more questions.
As you suggested, I tried to add the markers one by one.
Unfortunately, it looks like it can’t be done this way because the
“fullbodymodel”'s position is driven by it’s CoM. This is incompatible
with my marker’s positions.
So I tried to constraint it as follow:
  • Right and left heel: Y (2)
  • Right and left maleolus: X, Y, Z (6)
  • Right hip add/abd = Left hip add/abd: X (1)
  • Right ASIS: Z (1)
    TOTAL: 10
This replaces these drivers:
  • Right and left toe: Y (2)
  • Right and left ankle: X (2)
  • CoM on global ref: X, Z (2)
  • Right and left hip add/abd: X (2)
    TOTAL: 10
NOTE: All other drivers are unchanged.
The model compiles and loads without over or under determinacy of the
kinematics constraints. But when I try to set the initial conditions,
I get the “constraint above error tolerance” errors.
My questions:
  1. Can we assume that the first constraint that is named in the list
    of constraints that are above tolerance is the source of the problem?
  2. What’s wrong with my logic?
NOTE: I uploaded my model source to the file section, as two (2) RAR
files called ARep-LIO.RAR and BRep-LIO.RAR under “Jean-Olivier’s Project”.
Thank you very much!
Jean-Olivier
— In anyscript@yahoogroups.com, “AnyBody Support” <support@a…> wrote:
> Hi Jean-Oliver
on the model and the free floating makrer
measured in the z direction between the human marker and the free
floating asis markers needs to add up to be exact the error on the
sacrum marker measured in z. So what we are trying to do is to
distribute the error between the three markers. It do not mean that
" the height of the sacrum needs to be twice the average height of the
model markers and the free floating markers needs to be that be given
according to the equation.
advices:
joints and then gradually one by one replace those by marker drivers.
this can be done from the main file.
model and remove, this number should never change, for the same body
model.
> Best regards
> AnyBody Support
> > Good afternoon,
Here is my
> > question:
constraint, the
to the
Therefore, it
> > Thanks,
> > Jean-Olivier
> > LIO - CHUM
Hi Oliver
I have been looking at your model, and uploaded a new
JointAndDrivers.any file to your directory, please search for
aybodysup to see the changes.
There are several problems, i have removed joint drivers on the
legs, the legs where driven by both markers and joint drivers. I do
not think it was intentional, but i might be wrong.
I think you should still try to make it in smaller steps.
Include the file
#include “…\BRep\Aalborg\BodyModels\TwoLegs\BodyModel_Mus3E.a
ny”
instead of the full body model and make sure that this is driven
correctly before you move on to the fullbody.
Make sure you know the orientation of the local coordinate systems
if you use them. It is a good idea to make a small sketch of the
model and how it is driven. But i would start by driving it like we
do on the gait model if possible.
Using the legs only you should use 18 divers, you can see how the
gait model is driven in this presentation
http://www.anybodytech.com/fileadmin/examples/GaitWebcast.pdf
(you need to log in to see it)
If you make a stetch on the drivers you use i would be happy to see,
and comment it.
I hope this moves you in the right direction, even though it does
not solves all the problems.
About the error message: in general look for the largest number,
this will normally give you a good indication of the root fo the
problem.
AnyBody support
— In anyscript@yahoogroups.com, “jeanolivierracine” <jean-
> Hi again,
incompatible
> - Right and left heel: Y (2)
> - Right and left maleolus: X, Y, Z (6)
> - Right hip add/abd = Left hip add/abd: X (1)
> - Right ASIS: Z (1)
> TOTAL: 10
> - Right and left toe: Y (2)
> - Right and left ankle: X (2)
> - CoM on global ref: X, Z (2)
> - Right and left hip add/abd: X (2)
> TOTAL: 10
the
conditions,
> My questions:
list
problem?
RAR
Project”.
> Jean-Olivier
wrote:
> > Hi Jean-Oliver
marker
marker
on
that
the
the
given
> advices:
drivers.
body
> model.
questions.
> > Best regards
> > AnyBody Support
> > > Good afternoon,
markers. As a
presentation.
> Here is my
> > > question:
> constraint, the
According
> to the
> Therefore, it
average
> > > Thanks,
> > > Jean-Olivier
> > > LIO - CHUM
