environment object connection with human
1)when connecting a object with human body at a single connection point, the initial conditions and kinematics is achieved, but when i give a second attachment constrain, i am getting tolerance error for many default constrains. how can i achieve it. kindly help.
2)also is it right to keep the constraint type of the kinematics of the environment object as “Soft” always. If i keep it hard, then there is kinematic error.
AnyKinEq Exo_top_Connection =
AnyKinLinear lin =
AnyRefFrame &base = Main.HumanModel.BodyModel.Left.Leg.Seg.Thigh.humanlegtop;
AnyRefFrame &target = Main.Model.exoassembly.thigh___1.exoassembly_Hinge1 ;
Ref = 1;
AnyKinRotational rot =
Type = PlanarAngles;
Reaction.Type = {Off, Off, Off, Off, Off, Off};
AnyKinEq Exo_Thigh_Connection =
AnyKinLinear lin =
AnyRefFrame &base = Main.HumanModel.BodyModel.Left.Leg.Seg.Thigh.humanlegmid;
AnyRefFrame &target = Main.Model.exoassembly.thigh___1.exoassembly_Hinge2 ;
Ref = 0;
Position analysis failed : 561 independent constraints and 565 unknowns
- attempts to continue (attempt no. 1)
Failed to resolve kinematic constraints. Newton relaxation too small. (final kin. error = 1.699933E+000)
Constraint no. 331 above error tolerance 0.000001, error = 0.038000.
Constraint no. 337 above error tolerance 0.000001, error = 0.034000.
Constraint no. 343 above error tolerance 0.000001, error = 0.032000.
Constraint no. 349 above error tolerance 0.000001, error = 0.020000.
Constraint no. 355 above error tolerance 0.000001, error = 0.006500.
Constraint no. 364 above error tolerance 0.000001, error = 0.025593.
Constraint no. 365 above error tolerance 0.000001, error = 0.025593.
Constraint no. 372 above error tolerance 0.000001, error = 0.136000.
Constraint no. 376 above error tolerance 0.000001, error = 0.014700.
Constraint no. 377 above error tolerance 0.000001, error = 0.014700.
Constraint no. 384 above error tolerance 0.000001, error = 0.121000.
Constraint no. 388 above error tolerance 0.000001, error = 0.002554.
Constraint no. 389 above error tolerance 0.000001, error = 0.002554.
Constraint no. 396 above error tolerance 0.000001, error = 0.111000.
Constraint no. 400 above error tolerance 0.000001, error = 0.003813.
Constraint no. 401 above error tolerance 0.000001, error = 0.003813.
Constraint no. 408 above error tolerance 0.000001, error = 0.096000.
Constraint no. 412 above error tolerance 0.000001, error = 0.005571.
Constraint no. 413 above error tolerance 0.000001, error = 0.005571.
Constraint no. 420 above error tolerance 0.000001, error = 0.086000.
Constraint no. 421 above error tolerance 0.000001, error = 0.032000.
Constraint no. 422 above error tolerance 0.000001, error = 0.072500.
Constraint no. 425 above error tolerance 0.000001, error = 0.020000.
Constraint no. 430 above error tolerance 0.000001, error = 0.050000.
Constraint no. 431 above error tolerance 0.000001, error = 0.010000.
Constraint no. 436 above error tolerance 0.000001, error = 0.050000.
Constraint no. 437 above error tolerance 0.000001, error = 0.010000.
Constraint no. 460 above error tolerance 0.000001, error = 0.001397.
Constraint no. 461 above error tolerance 0.000001, error = 0.001933.
Constraint no. 462 above error tolerance 0.000001, error = 0.000130.
Constraint no. 484 above error tolerance 0.000001, error = 0.001397.
Constraint no. 485 above error tolerance 0.000001, error = 0.001933.
Constraint no. 486 above error tolerance 0.000001, error = 0.000130.
Constraint no. 490 above error tolerance 0.000001, error = 0.107903.
Constraint no. 491 above error tolerance 0.000001, error = 0.159836.
Constraint no. 492 above error tolerance 0.000001, error = 0.097675.
Constraint no. 493 above error tolerance 0.000001, error = 1.699933.
Constraint no. 494 above error tolerance 0.000001, error = 0.169051.
Constraint no. 495 above error tolerance 0.000001, error = 0.223926.
Constraint no. 496 above error tolerance 0.000001, error = 0.063162.
Constraint no. 497 above error tolerance 0.000001, error = 0.159097.
Constraint no. 498 above error tolerance 0.000001, error = 0.175338.
Constraint no. 499 above error tolerance 0.000001, error = 1.699933.
Constraint no. 500 above error tolerance 0.000001, error = 0.169051.
Constraint no. 501 above error tolerance 0.000001, error = 0.223926.
Constraint no. 502 above error tolerance 0.000001, error = 0.095848.
Constraint no. 503 above error tolerance 0.000001, error = 0.500000.
Constraint no. 508 above error tolerance 0.000001, error = 0.160138.
Constraint no. 509 above error tolerance 0.000001, error = 0.169874.
Constraint no. 510 above error tolerance 0.000001, error = 0.089817.
Constraint no. 516 above error tolerance 0.000001, error = 0.160138.
Constraint no. 517 above error tolerance 0.000001, error = 0.169874.
Constraint no. 518 above error tolerance 0.000001, error = 0.089817.
Constraint no. #0 in ‘Main.HumanModel.BodyModel.Trunk.Buckle.Slider1.Slider1Jnt.Constraints’ above error tolerance 0.000001, error = 0.038000.
Constraint no. #0 in ‘Main.HumanModel.BodyModel.Trunk.Buckle.Slider2.Slider1Jnt.Constraints’ above error tolerance 0.000001, error = 0.034000.
Constraint no. #0 in .
ERROR(OBJ.MCH.KIN3) : C:/P…)/A…y/A…3/AMMR/A…n/E…s/S…l/StandingModel.Main.any : Study.InitialConditions : Kinematic analysis failed in time step 0
Without your model, we can’t give you any advice on these errors.
If you upload your model on our debug section, then we will try to have a look at it:
