export problem
However big the model is, when I used export (Model Report (xml)), the software will not response, and the exported file keeps increasing in size (up to tens of GB). I never waited to the end, but I think the exported file can be infinite size…Why?
Thank you.
There seems to be a problem with the documentation in the script, the one of the type /** or ///. It works ok when removing those, so i think you can do that for now until the problem is properly solved.
They are usualy found at the top of the main file, but there may be more in the script, you will have to search a little.
Best regards, Sylvain.
