„Export Surface“ to *.stl doesn’t work in AnyBody 5
I have to issues:
  1. I was trying to export the femur in the AnyBody V5 but it does not work anymore!
  2. I would like to built a advanced joint with the new functionality “force dependent kinematics” and the contact possibility (AnyKinPointSurface ). Is it possible to use the “AnySurfSTL” function to create a surface for the about mentioned object?
You are right about the surface export. Thank you for finding the bug.
The AnyKinPointSurface works with analitical surfaces, spheres ellipsoids and cylinders. You can approximate the stl surface with the above mentioned surfaces or with the point cloud.
Best regards, Sylvain.
