Thanku Sir for now clearing my doubt.Thanks for your suppport.
Regards
Mohit.
Sir
I want to know that the constraints that are applied by converter.These are which type of constraints like displacement constraints etc or anything else?
Mohit
Hi Mohit,
I believe you are asking about the constraints on the entire body, not the node-surface coupling constraints (that you could read about in the manual).
The converter does not impose any kinematic constraints, the forces acting on the bone are supposed to balance it out. The inertia relief option is also switched on. Please refer to the Abaqus manual for more detail.
Sir
i just show that femur with the spiral web muscle attachments to my guide.Then they ask me what type of constraints is it?
Mohit
It is a coupling constraint between a node and a part of the specified surface.
Please refer to the Abaqus keyword manual to read more about *coupling keyword.
Hi Sir
I want to calculate the total values of loads or i want to summarize total loads. In the text files i have 172 muscle units.Is i have to add the values of various units according to x,y and z coordinates?
Thanks.
Mohit.
You could do it within in AnyBody by utilizing AnyForceMomentMeasure2 class object. Please read the manual and search the forum for examples.
