FEA Output
Hi AnyBody Team,
I just read the post of Prof. Dendorfer (06-29-2010) related to the content of the AnyMechOutputFileForceExport. He points out that forces by wrapping muscles are not included. Therefore I had a look in the xml-output file and noticed that WrapSurf’s are included but almost every entry is zero. Exept two entries for GastroWrapSurf.
In another thread I was told that the BM-statements for muscle wrapping are not included yet. Is it right if I assume that up from the next release all my forces due to wrapping points will turn into WrapSurf-non-zero entries in the xml-output file?
felix
Post of Prof. Dendorfer:
http://forum.anyscript.org/showthread.php?t=2585&highlight=wrapping
Felix,
wrapping surface related muscle forces were added some time ago. Now you can see ‘sliding’ effect resulting in different positions of the muscle force application position.
By default many wrapping surfaces are switched on. And BM statement related message probably meant something less global.
