Gait Uni Miami problems
Edit: I have managed to solve the problem, aparently the data had errors at the end of the file otherwise everything worked out fine.
I would like to congratulate the team - AnyBody is really a great software with a wide field of possible use.
Hello, I’m currently trying to add a new set of data to the GaitUniMiami application and am having trouble in step 12 of the process, i’ve managed to get the model very close to the original position and have modified the marker positions on the model. I’m using a new dataset with 13 markers, and have made all necessary modifications to include these.
What happens is that I get a kimematic error when running the SCALE studytype. I’ve tried altering marker positions and all I get is more errors than before. This is as close as I was possible to get the model to.
I have used a standard set of markers defined in the way shown in the book by Vaughan.
I was wondering if anyone could take a look at the model and point me in the right direction.
I have uploaded the file in this location:
