Hello everyone,
I used GRF prediction for a MoCap-driven model in AMMR 3.2.0. To analyze the failure of the GRF prediction in more detail, I looked at the linear weak recruited residuals.
AnyRecruitedActuator Linear_1 = {
AnyKinMeasure& ref= ..Measures.LinearCOM;
Type = NonNegative;
Strength = 5;
SET_DEFAULT_ACTUATOR_VOLUME;
with three force components:
AnyVar PosX_Force = WeakRecruitedResiduals.Linear_1.Fout[0]+WeakRecruitedResiduals.Linear_2.Fout[0];
AnyVar PosY_Force = WeakRecruitedResiduals.Linear_1.Fout[1]+WeakRecruitedResiduals.Linear_2.Fout[1];
AnyVar PosZ_Force = WeakRecruitedResiduals.Linear_1.Fout[2]+WeakRecruitedResiduals.Linear_2.Fout[2];
In a successful trial (left plot), the residuals are very small, as expected. In a failed trial (right plot), however, the Fout[0], and thus PosX_Force, is significantly increased, also as expected. But the increase in the x-direction confuses me, since I would have expected an increase in the vertical direction (z in the global coordinate system). However, as far as I understand, the segment coordinate systems are not always identical to the global coordinate system. How can I determine which global direction these three residual force components refer to? In other words, in which global direction have the residuals increased the most (Fout[0])?
Thanks for your help.
Caroline
