headline in AnyOutputFile
Dear colleagues,
i found many hints regarding formatting the outputfile, but didn’t find a way to print a header for the columns. Is there a way for this?
Thomaz
Dear Thomaz,
Header.ColumnNamesOnOff = On; - will allow you to print the names of the output variables.
Please see the template for AnyOutputFile class.
  AnyOutputFile <ObjectName> =
    FileName = "";
    /*NumberFormat =
    Digits = 15;
    Width = 22;
    Style = ScientificNumber;
    FormatStr = "";
    //Search = ;
    //SepSign = ",";
    //LineSepSign = "";
    /*Header =
    TitleSectionOnOff = On;
    ConstSectionOnOff = On;
    VarSectionOnOff = On;
    LinePrefix = "";
    AnyValue/*Use a AnyValue-derived class*/ <Insert name0> = <Insert value or expression>;
    //AnyValue/*Use a AnyValue-derived class*/ <Insert name1> = <Insert value or expression>; You can make any number of these objects!
