Dear colleagues,
I courteously ask for your help!!
I’m dealing with a MoCap model consisting in the full mannequin (AMMR v.1.6.3) sitting on a chair. The mannequin position is defined by using own .c3d data acquired from a sitting subject (according to VICON protocol). Mannequin height and weight in ‘TrialSpecificData.any’ are that of the acquired subject.
I used the model in the following AMMR repository, containing a chair model: :\AnyBody\AMMR\Application\Validation\WilkeSpinalDiscPressure\SpinePressureSeatingRelaxed. (Anybody version is 6.0.4).
Then, I simplified the chair model (just seat and backrest). Feet are placed on the ground. The chair placement matches that of the real chair where the acquired subject sited.
I need to evaluate the contact forces between the mannequin and the chair surfaces. Contact points were defined for the vertebrae, for pelvis and for thighs (‘SeatSupport.any’ and ‘BackrestSupport.any’).
Model runs correctly (no errors), but something that seems not correct happens in the results of the contact forces.
I upload the files. Parameter optimization step was already done (the resulting files are in the \Input folder) and you can thus run the InverseDynamic step directly (or otherwise you can repeat the Optimization step if you prefer).
As you will see running the model, the contact forces result concentrated in single contact points instead being distributed along all the contact points that are close to the seat surfaces.
I tried to change the limits for the strength measure function (in ‘SeatSupport.any’ and ‘BackrestSupport.any’) but nothing changed.
Important notices:
- differently from the original sitting model (that from the AMMR repository), in my model no joints are defined to connect the mannequin and the chair since the mannequin position is calculated according to the .c3d data.
- the model form the AMMR repository accounted for the InverseDynamic step only whereas my model (MoCapModel) accounts for Optimization and then InverseDynamic.
Do you have any helping or solving idea??? Am I making mistakes??
Thanks a lot in advance!
Tito
