I was wondering if it is possible to get the hip contact forces in the hip joints in the same coordinate system as in Orthoload. Or how can I transfer the AnyBody coordinate system?
And i get:
Scanning…
Parsing…
Constructing model tree…
ERROR(SCR.PRS2) : Y:/A…y/A…4/A…n/M…s/G…t/orthoload_coords.any : ‘sRel’ : Object already auto declared by owner : Main.Studies.OrtholoadCoords.OrtholoadRefFrame
Model loading skipped
Where exactly are the hip joint forces located in the GaitLowerExtremity model?
Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.Hip.Constraints.Reaction
Main.Studies.InverseDynamicStudy.Output.HumanModel.Left.Leg.MomentMeasure.HipNetMoment
don’t work.
How can I process the forces? I thought they could be found in Main.Studies.InverseDynamicStudy.Output.HumanModel.Left.Leg.JntDOF.Hip.Constraints.Reaction.Fout but that doesn’t work either.
please try not to change the files in the Body section. This will also affect the other models in the repository and might lead to unwanted changes in the other models.
if you include following lines in the Study of your GaitLowerExtremity it will work.
I open up first the HipJoint Node and create a new coordinate system in there (New_CS) and then…
Thank you Amir, the model is running now, without errors. Unfortunately the forces are quite unexpected but I guess that is another problem which is not dependant on the chosen coordinate systems.
One more small question:
The values given in
Main.Studies.InverseDynamicStudy.Output.HumanModel.Right.Leg.JntDOF.Hip.Constraints.Reaction.Fout
are in Newton, they are not normalized with body weight?
