Hi there,
I have a question about Units.
I don’t know how to change from ‘Radian’ to ‘Degree’.
Do i have to modify some code like (180/pi)?
Thank you,
Hi there,
Thank you,
Hi Dwan Lee,
I usually use a linear combination measure to do this:
AnyKinMeasureLinComb Rotations_in_degrees = {
AnyKinRotational rot = {
Type = RotAxesAngles;
AnyRefFrame &<Insert name0> = <Insert object reference (or full object definition)>;
//AnyRefFrame &<Insert name0> = <Insert object reference (or full object definition)>;
Coef = {{1,0,0}, {0,1,0},{0,0,1}}*180/pi;
OutDim = 3;
This particular example gives all 3 rotations as output, but you could easily do it just for one or two if you rather.
Or you can also use expressions if you want:
AnyVar KneeAngle_degree = KneeAngle_Radian*(180/pi)
Best Regards,
Christine
Hi Christine,
Thank you for your answer. You gave me what i want to do
Hugely thanks,
Dwan
