hi~
After Running the MoCap_FullBody.main in the Folder MoCapModel , I want to view the moments at the low back(L5-Sacrum Joint) in the Chart2D/3D,
But I did not find the relevant information,
I need to define those? or do other things?
Thank you
hi~
Thank you
If you look in the AnyChart under:
Main.Studies.InverseDynamicStudy.Output.BodyModel.SelectedOutput.Trunk.JointReactionForce
Main.Studies.InverseDynamicStudy.Output.BodyModel.SelectedOutput.Trunk.JointMomentMeasure
you can see what is available. The Lumbar joints are modeled as spherical joints, therefore there are no moments.
