When I use GaitLowerExtremity without force plates I can run Inverse Dynamics Properly. Yesterday I defined the Cal_Matrices for the force plates and it was implemented perfectly. I’ve used the optimization sequence, but when I want to start the Inverse Dynamics Sequences I will get this error
.0) Inverse dynamic analysis… [SIZE=1]ERROR(OBJ.MCH.MUS4)[/SIZE] : [SIZE=1]InverseDynamicStudy.InverseDynamics[/SIZE] : Muscle recruitment solver : solver aborted after maximum number of line-search iterations
What can I do to fix it? I have attached the complete model.
Hi Hans,
sorry, I don’t really understand. Without force plates the Inverse Dynamics should not work at all. The model you send seems to have some kinematic error, is it really the one you got the described error with?
The error you got usually indicates a unbalanced problem, please check the force directions of the forceplates.
Sebastian
