Hello. I need joint force direction vector angle (angle in degrees or radians) when {0, 30, 60) represents the elbow flexion angle in degrees. I attach my model. What should I do?
Attached please find a modified version of your model which enables the visualization of the elbow joint reaction forces.
Here is the pieces of code which I’ve added to your original main file:
HumanModel.Right.ShoulderArm.Seg.Humerus.fe =
AnyRefNode ReferenceNode =
ARel = RotMat(-pi/2, y);
AnyDrawRefFrame DrwFrame =
RGB = {1, 0, 0};
ScaleXYZ = 0.1*{1, 1, 1};
AnyForceMomentMeasure2 ReactionMeasure =
AnyForceBase& reac = .HumanModel.Right.ShoulderArm.Jnt.FE.Constraints.Reaction;
AnyRefFrame& ref = .HumanModel.Right.ShoulderArm.Seg.Humerus.fe.ReferenceNode;
AnySeg& seg = .HumanModel.Right.ShoulderArm.Seg.Humerus;
AnyVec3 Flocal = F * ref.Axes;
AnyVec3 Mlocal = M * ref.Axes;
AnyDrawVector DrawReaction =
AnyRefFrame& ref = .HumanModel.Right.ShoulderArm.Seg.Humerus.fe.ReferenceNode ;
Vec = .ReactionMeasure.Flocal * Main.DrawSettings.DrawSettingsSupport.Lin.ScaleFactor;
GlobalCoord = Off;
PointAway = On;
Line =
RGB = {1, 1, 1};
Thickness = 0.005;
End.Style = Line3DCapStyleArrow ;
Flocal variable in the ‘ReactionMeasure’ object will display the local representation of the elbow joint reaction force.
So I think you can simply calculate the necessary angle by using some vector operations.
I hope this may help you.
Moonki Jung
