Hi Justyna,
By default, the reaction force components are expressed in the first (Frame1) of the two sequentially defined reference frames/nodes (Frame1,Frame2) during joint specification. If you go to the ‘Jnt.Any’ file where the hip joint is defined, the thigh node is our Frame1. So the 0,1 and 2 components of ‘Reaction.Fout’ are also the x,y and z directions of the coordinate frame associated with the thigh node. You could visualize this frame using the ‘AnyDrawRefFrame class’ (See Tutorials, Getting Started: Anyscript programming, Lesson 3). We have left this as general because some of our users may want to create their own reference frames.
The computed reaction force is that acting on Frame2 due to Frame1. Therefore, in this case it’s the force on the acetabulum due to the femoral head.
In the AnyForceMoment measure you have created, the measured force is that applied to the AnyRefFrame which is your thigh node of the hip joint. Therefore, it is the force of the acetabulum on the femoral head, which is why your Flocal is the negative of the default hip joint reaction force described in (2).
The elbow FE joint is an AnyRevoluteJoint. If you check the documentation in the Anyscript reference manual, the rotation is by default about the z axes of the two reference frames connected through this joint. So you would not have an internal reaction moment about the ‘z’ axis since the DOF is not constrained. But the remaining 5 constrained DOFs between the humerus and the ulna will report some reaction forces.
Similar to my point in number (2) since the node on the humerus is Frame1 in the elbow AnyRevoluteJoint definition, the reaction force components will be expressed in that coordinate system. However the force itself is that acting on the ulna (Frame2) due to the humerus (Frame1). You should be able to visualize the joint reaction force using the AnyDrawVector or AnyDrawLine classes.
Hope this helps.
Ananth,
