Hello to everybody again,
I tried to run the motion and parameter optimization for the GaitFullBody model (I am using the AMMR.v1.6).
I just copy the folder AMMR.v1.5-MyDemo\Application\Examples\GaitFullBody of the version AMMR.v1.5.
And in the main file (GaitFullBody.main.any) i set active the MotionAndParameterOptimizationModel, as follows
#ifndef MotionAndParameterOptimizationModel
#define MotionAndParameterOptimizationModel 1
#endif
//Set this to 1 if you want to run the inverse dynamic analysis
#ifndef InverseDynamicModel
#define InverseDynamicModel 0
#endif
That is all i did…and i have the following error:
ERROR(OBJ.MCH.KIN3) : P:/P…s/P…y/A…o/A…n/A…d/T…y/GaitFullBody.main.any(233) : MotionOptimization.InitialConditions : Kinematic analysis failed in time step 0
Thank you in advance for your help!
Arnaud
