Load location
I want to model some tasks based on location of loads. Is there any solution to model with AnyBody using location of load (instead of rotations of segments) ? Do I have to check position of HandNode after setting rotations of segments frequently, as a trial and error method?
Best,
Mohamad
Hi Mohamad,
In the hand segment there is an AnyRefNode object of which name is ‘PalmJoint’. You can try with that node.
Also I would recommend you to define your own node by changing its sRel values manually.
There is no special solution for this.
