lumbar joint force function
How is the function defined? Where can I see the function. I want to see which muscles are responsible in the model to the spine joint force.
Thank you very much.
Please check the manual for AnyMechOutputFileForceExport class and/or the FE interface tutorial. This class allows for outputting all forces acting on a particular segment. To find all reaction forces acting on the joint please check the SelectedOutput subfolder of the model, e.g. Main.HumanModel.BodyModel.SelectedOutput.Trunk.JointReactionForce.*.
