Making Trajectory Visible
I tried running the code provided on the following wiki page for making trajectories visible.
http://wiki.anyscript.org/images/4/41/Trajectory2.any
However, I didn’t see any trajectory in the model view window though the script ran successfully in the forward kinematics mode but not in the inverse kinematics mode as there are no muscles in the model. I even tried changing the RGB and line thickness values but no improvement.
Could anyone suggest how the trajectory can be made visible.
Priyanshu
Hi Priyanshu,
The code is correct, the problem comes from the model view itself. In version 4.0 it was not able to display the anychart that is used to draw trajectories. I suppose this is the version you have.
Please try the latest release of version 4.1, it should fix the problem.
Best regards, Sylvain.
Thank you Sylvain.
