MaxMuscleActivity
Does the MaxMuscleActivity plot the corrected or uncorrected values?
Brent
Hi Brent
I guess that it is the uncorrected values, because there is a AnyVar
called CorrectedActivity
Regards Christian
blulrey wrote:
> Hello,
> Brent
Hi again Brent
Well the activity and the CorrectedActivity is of cause the same if you
are using the simple muscle model.
If you are using the 3element muscle model, the activity is the
“activity” before correction. The CorrectedActivity is the activity
after correction.
I took a look at the Anybodytech homepage:D
Hope it helps:D
Regards Christian
blulrey wrote:
> Hello,
> Brent
Hi Christian,
I realize that there are 2 variables for activity called: Activity and
CorrectedActivity. My question was, when using the 3 element model or
a mix of simple and 3 element, does the chart plot the corrected
maximum values when you choose MaxMuscleActivity?
Thank you,
Brent
— In anyscript@yahoogroups.com, Christian Gammelgaard <cgol03@…>
wrote:
> Hi again Brent
> after correction.
> Hope it helps:D
> Regards Christian
> blulrey wrote:
> > Hello,
> > Brent
Hi Brent
Sorry… didn’t realize that your question was related to the
MaxMuscleActivity…:-/
Well the MaxMuscleActivity is calculated during the muscle recruitment
and the CorrectedActivity is calculated after the muscle recruitment,
and therefore the MaxMuscleActivity is only based on the Activity, not
the CorrectedActivity.
Regards Christian
blulrey skrev:
> Hi Christian,
> Thank you,
> Brent
> — In anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>,
> wrote:
> > Hi again Brent
> > after correction.
> > Hope it helps:D
> > Regards Christian
> > blulrey wrote:
> > > Hello,
> > > Brent
Thanks Christian! I thought that was the case, but wanted to be sure.
So with 3 element muscle models, I’ll resort to my own postprocessing
to obtain the max corrected activity.
Also, I noticed that sometimes the results for activity and corrected
activity are greater than 1. By the definition of activity, shouldn’t
it always be less than or equal to 1?
Brent
wrote:
> Hi Brent
> Regards Christian
> blulrey skrev:
> > Hi Christian,
> > Thank you,
> > Brent
> > Christian Gammelgaard <cgol03@>
> > wrote:
> > > Hi again Brent
if you
> > > after correction.
> > > Hope it helps:D
> > > Regards Christian
> > > blulrey wrote:
> > > > Hello,
values?
> > > > Brent
Hi Brent
Ok… you are welcome:D. The difference should be very small…
Well the activity can be more than one, if the muscle has to work harder
than it actually can…
It can be caused by various reasons, depending on how the actual muscle
force was estimated, poor filtering of kinematic data etc.
But yes in theory the muscle activity should be 1 or less. There are
different ideas about how strong a muscle is, and with what force a cm2
of muscle fibers can pull. I think it is just a think that can happen
when you try to model the physiology:-/
Regards Christian
> Brent
> wrote:
> > Hi Brent
> > Regards Christian
> > blulrey skrev:
> > > Hi Christian,
> > > Thank you,
> > > Brent
> > > wrote:
> > > > Hi again Brent
> if you
> > > > after correction.
> > > > Hope it helps:D
> > > > Regards Christian
> > > > blulrey wrote:
> > > > > Hello,
> values?
> > > > > Brent
So if I am getting corrected muscle activities greater than 1, what
can be concluded? Does that mean that the motion is impossible with
the strength of the muscles in the model? I need to know how to interpret
activities greater than 1.
Thank you,
Brent
wrote:
> Hi Brent
harder
> Regards Christian
> > Brent
> > wrote:
> > > Hi Brent
recruitment
recruitment,
Activity, not
> > > Regards Christian
> > > blulrey skrev:
> > > > Hi Christian,
Activity and
model or
> > > > Thank you,
> > > > Brent
> > > > wrote:
> > > > > Hi again Brent
> > if you
activity
> > > > > after correction.
> > > > > Hope it helps:D
> > > > > Regards Christian
> > > > > blulrey wrote:
> > > > > > Hello,
> > values?
> > > > > > Brent
Hi Brent
Yes… muscle activities greater than one means that the muscle has to
pull with greater force than possible. I don’t know how you are driving
the model, but for instance our model is driven by kinematic recordings
and because the filtering wasn’t sufficient which gave us huge
accelerations that wasn’t possible for the muscles to follow. This gave
us very high muscle activities (>100).:-/
How you should interpret the results I don’t know… probably need
more specifications from the model you are working on… How you drive
it and soo on…
Regards Christian
> Thank you,
> Brent
> wrote:
> > Hi Brent
> harder
> > Regards Christian
> > > Brent
> > > wrote:
> > > > Hi Brent
> recruitment
> recruitment,
> Activity, not
> > > > Regards Christian
> > > > blulrey skrev:
> > > > > Hi Christian,
> Activity and
> model or
> > > > > Thank you,
> > > > > Brent
> > > > > wrote:
> > > > > > Hi again Brent
> > > if you
> activity
> > > > > > after correction.
> > > > > > Hope it helps:D
> > > > > > Regards Christian
> > > > > > blulrey wrote:
> > > > > > > Hello,
> > > values?
> > > > > > > Brent
Christian,
Okay, that makes sense. My model is very simple at this time since I
am just learning to use the program. I started with the default
standing model in the repository, changed the posture to a bent over
position, and then added loads in the hands in the downward direction.
Your model sounds interesting, especially since you are driving it
with actual kinematic data. It would be good to know how to do that,
however I’m not sure yet if I’ll need that capability.
Brent
wrote:
> Hi Brent
> it and soo on…
> Regards Christian
interpret
> > Thank you,
> > Brent
> > wrote:
> > > Hi Brent
> > harder
muscle
force a cm2
happen
> > > Regards Christian
be sure.
postprocessing
corrected
shouldn’t
> > > > Brent
> > > > wrote:
> > > > > Hi Brent
> > recruitment
> > recruitment,
> > Activity, not
> > > > > Regards Christian
> > > > > blulrey skrev:
> > > > > > Hi Christian,
> > Activity and
> > model or
corrected
> > > > > > Thank you,
> > > > > > Brent
> > > > > > wrote:
> > > > > > > Hi again Brent
the same
> > > > if you
is the
> > activity
> > > > > > > after correction.
> > > > > > > Hope it helps:D
> > > > > > > Regards Christian
> > > > > > > blulrey wrote:
> > > > > > > > Hello,
uncorrected
> > > > values?
> > > > > > > > Brent
Hi Brent
Ok…thanks… you are always welcome to ask:D And I will help as much
as possible:D
If it is needed I can give you a short introduction if you need it.
Regards Christian
blulrey wrote:
> Christian,
> Brent
> wrote:
> > Hi Brent
> > it and soo on…
> > Regards Christian
> interpret
> > > Thank you,
> > > Brent
> > > wrote:
> > > > Hi Brent
> > > harder
> muscle
> force a cm2
> happen
> > > > Regards Christian
> be sure.
> postprocessing
> corrected
> shouldn’t
> > > > > Brent
> > > > > wrote:
> > > > > > Hi Brent
> > > recruitment
> > > recruitment,
> > > Activity, not
> > > > > > Regards Christian
> > > > > > blulrey skrev:
> > > > > > > Hi Christian,
> > > Activity and
> > > model or
> corrected
> > > > > > > Thank you,
> > > > > > > Brent
> > > > > > > wrote:
> > > > > > > > Hi again Brent
> the same
> > > > > if you
> is the
> > > activity
> > > > > > > > after correction.
> > > > > > > > Hope it helps:D
> > > > > > > > Regards Christian
> > > > > > > > blulrey wrote:
> > > > > > > > > Hello,
> uncorrected
> > > > > values?
> > > > > > > > > Brent
