New Features in AnyBody v6.0 and Repository
I’m using AnyBody v4.0 and doing some projects with it. How can I find out the differences between new version and previous ones?
I’m concerned that new features added to new versions will affect my results which is lumbar disk forces.
Mohamad
Hi Mohamad,
You can check the Release Notes in the installation folder to see what has changed. We would recommend to switch to the newer version since the software has been improved. You model should still run, but there might, of course, be some changes depending on what features you used.
And we will, of course, help if something does not work.
