Parameter values in study output
Hi! :slight_smile:
Probably a simple question, but I could not find any answer in the manual or forum. I did some calculations in AnyBody by using AnyVec3 and AnyVar, which I would like to visualize after the simulation. However, the variables are not saved in the study output (since there is e.g. no measure obejct?). Is there a solution for this problem without an export (AnyOutputFun)?
Thanks and best regards,
mulle
Dear Mulle,
  1. As you pointed out, if you can export your data into some text files then you can open it in some external software such as excel.
  2. If you want to use your output inside the AnyBody, then AnyOutputFun can be an option. I would recommend you to see the GaitVaughan model in AMMR.
