assalamualaikum and very good day
how to determine the ref node on the body segment.
for example hand.
thanks
for example hand.
thanks
What do you mean by determine?
You can visualize a refnode by
[ul]
[li]selecting it in the modeltree
[/li][li]right click
[/li][li] select modelview
[/li][li] Select this object+ all levels
[/li][li] select autogenerated view
[/li][/ul]
In a similar way you can visualize the hand segment by selecting it and do the same sequence
We’ve seen your direct question on our email.
'I want to know how to move the arm linearly. So that i need to know what should be put at the driver and joint. ’
In the ‘Mannequin.any’ file in the ‘StandingModel’, you need to define joint angle position values and joint angle velocity values.
