Without being able to see the other drivers/measures in the model i can not see what goes wrong.
Here are some general rules to use:
[ul]
[li] Please make sure you are driving the correct dof i assume you the measure is a rotational measure? If so make sure you are using correct number in the sequence.
[/li][li] Is there a particular reason for using the fourier driver? it would be simpler to use the AnyKinEqSimpleDriver
[/li][li] From looking at your code i think the expression you have is this one: Pos = Main.PosX+0.02cos(2piMain.Freq1t)
[/li][li] please see the reference manual for more details it displays these equations.
[/li][li] Please also consider to make a small example with one segment and a joint to play around with the meaning of these settings.
[/li][/ul]
