Some questions.
I have some questions. They are listed below.
  1. When I run the inverse dynamics for my model. I got the error that
    says “Muscle recruitment analysis failed, simplex solver reports that
    solution does not satisfy all constraints” at step 77. I searched this
    forum and chanced upon the suggested solution to add a negligible
    gravity in the other 2 directions in the AnyBodyStudy such as
    Gravity={0.001,-9.81,0.001}. My model then runs smoothly with no
    errors. Does this mean that the problem is settled?
  2. I’m trying to do an AnyParamStudy like the one in the tutorial. I
    have 1 parameter to vary and I’d like to see how it affects the joint
    forces in the knee - which has Fx,Fy and Fz. How to I get the
    AnyDesMeasure to extract the vector sum of these forces?
  3. How do I find the center of mass of a body? Is it to use the
    AnyKinCoM function?
Thanks in advance.
Best Regards,
Robin
Hi Robin
  1. I believe that you did the right thing.
  2. Well You should as you do, follow the tutorial describing the
    parameter study. If you want to extract the joint forces, I believe
    you can insert a AnyForceMeasure and then use that as your
    AnyDesMeasure. I will look a bit more into this and get back later again.
  3. Yes if you want to measure the COM, then the AnyKinCOM measures the
    COM of the segments you want.
Christian, AnyBody Support
— In anyscript@yahoogroups.com, “Robin” <giggsyagami07@…> wrote:
> Hi,
> AnyKinCoM function?
> Thanks in advance.
> Best Regards,
> Robin
Hi Christian,
Thanks for the answers. I have another question.
I tried to scale my model using
#include “…\BRep\Aalborg\Scaling\ScalingUniform.any”
The kinematics seems ok without muscles on the model, and I could set
its initial positions. However, when I changed the model to one with
muscles, using
#include “…\BRep\Aalborg\BodyModels\FullBodyModel\BodyModel.any”,
The model wouldn’t set its initial postions and gave a total kinematic
error of (final kin. error = 5.643448E+000).
Why is this so?
Best Regards,
Robin
> Hi Robin
again.
> Best regards
> — In anyscript@yahoogroups.com, “Robin” <giggsyagami07@> wrote:
> > Hi,
> > AnyKinCoM function?
> > Thanks in advance.
> > Best Regards,
> > Robin
Hi Robin
I will look a bit more into that model… It sounds like you should
scale your initial positions as well, but I havent got a chance to
look at it yet… I will get back to you.
> Hi Christian,
> muscles, using
> #include
> Why is this so?
> Best Regards,
> Robin
> — In anyscript@yahoogroups.com, “AnyBody Support” <support@> wrote:
> > Hi Robin
> again.
> > Best regards
> > > Hi,
that
that
searched this
joint
> > > AnyKinCoM function?
> > > Thanks in advance.
> > > Best Regards,
> > > Robin
Hi Christian,
Sure, and thanks a lot again.
Robin
> Hi Robin
> Best regards
> > Hi Christian,
> > muscles, using
> > #include
> > Why is this so?
> > Best Regards,
> > Robin
> > > Hi Robin
> > again.
measures the
> > > Best regards
> > > > Hi,
> that
> that
> searched this
tutorial. I
> joint
> > > > AnyKinCoM function?
> > > > Thanks in advance.
> > > > Best Regards,
> > > > Robin
Hi Robin
Ok I was looking a bit into it, but now I would like to see the
model… please?
> Hi Christian,
> Regards,
> Robin
> > Hi Robin
> > Best regards
> > > Hi Christian,
could set
> > > muscles, using
> > > #include
kinematic
> > > Why is this so?
> > > Best Regards,
> > > Robin
wrote:
> > > > Hi Robin
believe
> > > again.
> measures the
> > > > Best regards
> > > > > Hi,
> > that
> > that
> > searched this
negligible
> tutorial. I
> > joint
> > > > > AnyKinCoM function?
> > > > > Thanks in advance.
> > > > > Best Regards,
> > > > > Robin
Hi Christian,
I have it zipped and posted up in the files section under the folder
called “Robin’s Work”.
Thanks. =)
Best Regards,
Robin
> Hi Robin
> model… please?
> Best regards
> > Hi Christian,
> > Regards,
> > Robin
> > > Hi Robin
> > > Best regards
> > > > Hi Christian,
> could set
one with
> > > > muscles, using
> > > > #include
> kinematic
> > > > Why is this so?
> > > > Best Regards,
> > > > Robin
> wrote:
> > > > > Hi Robin
> believe
later
> > > > again.
> > measures the
> > > > > Best regards
wrote:
> > > > > > Hi,
error
> > > that
reports
> > > that
> > > searched this
> negligible
with no
> > tutorial. I
affects the
> > > joint
use the
> > > > > > AnyKinCoM function?
> > > > > > Thanks in advance.
> > > > > > Best Regards,
> > > > > > Robin
Hi Robin
I took a look at your model. By removing the lines that makes the
errors in the InitialPosition.any (I uploaded the edited file to your
directory)
This will make the model run. I get a recruitment error at the 79th
time step. I haven’t found the actual problem, but it seems like it
comes from the hip. Try look at the hip at the 79th time step.
By the way you use the uniform scaling. I just want to remind you that
the recommended way of scaling is the LengthMassFat.
Let me hear how it goes.
> Hi Christian,
> Thanks. =)
> Best Regards,
> Robin
> > Hi Robin
> > model… please?
> > Best regards
> > > Hi Christian,
> > > Regards,
> > > Robin
wrote:
> > > > Hi Robin
should
> > > > Best regards
> > > > > Hi Christian,
> > could set
> one with
> > > > > muscles, using
> > > > > #include
> > kinematic
> > > > > Why is this so?
> > > > > Best Regards,
> > > > > Robin
> > wrote:
> > > > > > Hi Robin
describing the
> > believe
> later
> > > > > again.
> > > measures the
> > > > > > Best regards
> wrote:
> > > > > > > Hi,
> error
> > > > that
> reports
> > > > that
> > > > searched this
> > negligible
such as
> with no
> > > tutorial. I
> affects the
> > > > joint
get the
> use the
> > > > > > > AnyKinCoM function?
> > > > > > > Thanks in advance.
> > > > > > > Best Regards,
> > > > > > > Robin
Hi Christian,
Thanks a lot. I will take a look at it. Another problem I face is the
interaction between the human body and the seat. If you noticed, I
used spherical joints - somehow I don’t think it is right. Any
suggestions?
Best Regards,
Robin
> Hi Robin
> directory)
> Best regards
> > Hi Christian,
> > Thanks. =)
> > Best Regards,
> > Robin
> > > Hi Robin
> > > model… please?
> > > Best regards
> > > > Hi Christian,
> > > > Regards,
> > > > Robin
> wrote:
> > > > > Hi Robin
> should
chance to
> > > > > Best regards
wrote:
> > > > > > Hi Christian,
> > > could set
> > one with
> > > > > > muscles, using
> > > > > > #include
> > > kinematic
> > > > > > Why is this so?
> > > > > > Best Regards,
> > > > > > Robin
> > > wrote:
> > > > > > > Hi Robin
> describing the
> > > believe
> > later
> > > > > > again.
> > > > measures the
> > > > > > > Best regards
> > wrote:
> > > > > > > > Hi,
> > error
> > > > > that
> > reports
> > > > > that
> > > > > searched this
> > > negligible
> such as
> > with no
> > > > tutorial. I
> > affects the
> > > > > joint
> get the
> > use the
> > > > > > > > AnyKinCoM function?
> > > > > > > > Thanks in advance.
> > > > > > > > Best Regards,
> > > > > > > > Robin
Hi Robin
From my point of view it seems ok… I guess you could also do it with
a couple of markers.
> Hi Christian,
> suggestions?
> Best Regards,
> Robin
> > Hi Robin
> > directory)
> > Best regards
> > > Hi Christian,
> > > Thanks. =)
> > > Best Regards,
> > > Robin
wrote:
> > > > Hi Robin
> > > > model… please?
> > > > Best regards
> > > > > Hi Christian,
> > > > > Regards,
> > > > > Robin
> > wrote:
> > > > > > Hi Robin
> > should
> chance to
> > > > > > Best regards
> wrote:
> > > > > > > Hi Christian,
> > > > could set
> > > one with
> > > > > > > muscles, using
> > > > > > > #include
> > > > kinematic
> > > > > > > Why is this so?
> > > > > > > Best Regards,
> > > > > > > Robin
<support@>
> > > > wrote:
> > > > > > > > Hi Robin
> > describing the
forces, I
> > > > believe
get back
> > > later
> > > > > > > again.
> > > > > measures the
> > > > > > > > Best regards
> > > wrote:
> > > > > > > > > Hi,
got the
> > > error
> > > > > > that
> > > reports
> > > > > > that
> > > > > > searched this
> > > > negligible
> > such as
> > > with no
> > > > > tutorial. I
> > > affects the
> > > > > > joint
> > get the
> > > use the
> > > > > > > > > AnyKinCoM function?
> > > > > > > > > Thanks in advance.
> > > > > > > > > Best Regards,
> > > > > > > > > Robin
Hi Christian,
I’ve ammended the initial positions that you have suggested but it’s
still the same scaling problem. After scaling, the model runs
kinematically as expected.
But after adding muscles, the model seems to have some error. The
muscles look like they stick to the origin of the axes and the model
looks slanted.
I’ve posted the model up in Robin’s Work folder. Hope you’d have some
ideas/suggestions. Thanks.
Robin
> Hi Robin
> Best regards
> > Hi Christian,
> > suggestions?
> > Best Regards,
> > Robin
> > > Hi Robin
your
> > > directory)
you that
> > > Best regards
> > > > Hi Christian,
folder
> > > > Thanks. =)
> > > > Best Regards,
> > > > Robin
> wrote:
> > > > > Hi Robin
> > > > > model… please?
> > > > > Best regards
wrote:
> > > > > > Hi Christian,
> > > > > > Regards,
> > > > > > Robin
> > > wrote:
> > > > > > > Hi Robin
> > > should
> > chance to
> > > > > > > Best regards
> > wrote:
> > > > > > > > Hi Christian,
> > > > > > > > #include
and I
> > > > > could set
model to
> > > > one with
> > > > > > > > muscles, using
> > > > > > > > #include
total
> > > > > kinematic
> > > > > > > > Why is this so?
> > > > > > > > Best Regards,
> > > > > > > > Robin
Hi Robin
I can’t load the model because you use a AnySailor.any? I don’t have
that one?
I can change it to another one, but I don’t know how yours are?
> Hi Christian,
> looks slanted.
> Regards,
> Robin
> > Hi Robin
> > Best regards
> > > Hi Christian,
is the
> > > suggestions?
> > > Best Regards,
> > > Robin
wrote:
> > > > Hi Robin
> your
> > > > directory)
79th
like it
> you that
> > > > Best regards
> > > > > Hi Christian,
> folder
> > > > > Thanks. =)
> > > > > Best Regards,
> > > > > Robin
> > wrote:
> > > > > > Hi Robin
see the
> > > > > > model… please?
> > > > > > Best regards
> wrote:
> > > > > > > Hi Christian,
> > > > > > > Regards,
> > > > > > > Robin
<support@>
> > > > wrote:
> > > > > > > > Hi Robin
like you
> > > > should
> > > chance to
> > > > > > > > Best regards
> > > wrote:
> > > > > > > > > Hi Christian,
> > > > > > > > > #include
> and I
> > > > > > could set
> model to
> > > > > one with
> > > > > > > > > muscles, using
> > > > > > > > > #include
> total
> > > > > > kinematic
> > > > > > > > > Why is this so?
> > > > > > > > > Best Regards,
> > > > > > > > > Robin
Sorry about that. I’ve posted it up in the same folder. Thanks again.
Best Regards,
Robin
> Hi Robin
> that one?
> Best regards
> > Hi Christian,
> > looks slanted.
> > Regards,
> > Robin
> > > Hi Robin
it with
> > > Best regards
> > > > Hi Christian,
> is the
> > > > suggestions?
> > > > Best Regards,
> > > > Robin
> wrote:
> > > > > Hi Robin
makes the
> > your
> > > > > directory)
> 79th
> like it
> > you that
> > > > > Best regards
wrote:
> > > > > > Hi Christian,
> > folder
> > > > > > Thanks. =)
> > > > > > Best Regards,
> > > > > > Robin
> > > wrote:
> > > > > > > Hi Robin
> see the
> > > > > > > model… please?
> > > > > > > Best regards
> > wrote:
> > > > > > > > Hi Christian,
> > > > > > > > Regards,
> > > > > > > > Robin
> <support@>
> > > > > wrote:
> > > > > > > > > Hi Robin
> like you
> > > > > should
> > > > chance to
> > > > > > > > > Best regards
<giggsyagami07@>
> > > > wrote:
> > > > > > > > > > Hi Christian,
> > > > > > > > > > #include
> > and I
> > > > > > > could set
> > model to
> > > > > > one with
> > > > > > > > > > muscles, using
> > > > > > > > > > #include
> > total
> > > > > > > kinematic
> > > > > > > > > > Why is this so?
> > > > > > > > > > Best Regards,
> > > > > > > > > > Robin
Hi Robin
I get some big kinematic errors. By looking at the loaded model, it
seems like the model is not big enough… The legs are not long enough
and they split in the knee and ankle. It seems like you have attached
the model to the bench with spherical joints, which makes means that
the model have to fit perfectly to the bench, which not is the case. I
think I would take a look at the AnyKinEqSimpleDriver. By using a
driver you can make the foot follow the marker in the axis’ you like,
i.e. you can make the foot able to move in the longitudinal axis of
the leg but not up and down. Then it doesn’t matter how tall the model
is. Does it make any sense? or have I misunderstood something?
> Hi,
> Best Regards,
> Robin
> > Hi Robin
> > that one?
> > Best regards
> > > Hi Christian,
> > > looks slanted.
some
> > > Regards,
> > > Robin
wrote:
> > > > Hi Robin
> it with
> > > > Best regards
> > > > > Hi Christian,
> > is the
noticed, I
> > > > > suggestions?
> > > > > Best Regards,
> > > > > Robin
> > wrote:
> > > > > > Hi Robin
> makes the
file to
> > > your
> > > > > > directory)
> > 79th
> > like it
> > > you that
> > > > > > Best regards
> wrote:
> > > > > > > Hi Christian,
under the
> > > folder
> > > > > > > Thanks. =)
> > > > > > > Best Regards,
> > > > > > > Robin
<support@>
> > > > wrote:
> > > > > > > > Hi Robin
> > see the
> > > > > > > > model… please?
> > > > > > > > Best regards
> > > wrote:
> > > > > > > > > Hi Christian,
> > > > > > > > > Regards,
> > > > > > > > > Robin
> > <support@>
> > > > > > wrote:
> > > > > > > > > > Hi Robin
> > like you
> > > > > > should
got a
> > > > > chance to
> > > > > > > > > > Best regards
> <giggsyagami07@>
> > > > > wrote:
> > > > > > > > > > > Hi Christian,
> > > > > > > > > > > #include
model,
> > > and I
> > > > > > > > could set
> > > model to
> > > > > > > one with
> > > > > > > > > > > muscles, using
> > > > > > > > > > > #include
gave a
> > > total
> > > > > > > > kinematic
> > > > > > > > > > > Why is this so?
> > > > > > > > > > > Best Regards,
> > > > > > > > > > > Robin
Your interpretation sounds correct to me. Thank for the idea. I’ll
try it out.
Best Regards,
Robin
wrote:
> Hi Robin
enough
attached
that
case. I
like,
model
> Best regards
> > Hi,
again.
> > Best Regards,
> > Robin
wrote:
> > > Hi Robin
don’t have
> > > that one?
> > > Best regards
wrote:
> > > > Hi Christian,
but it’s
error. The
the model
> > > > looks slanted.
have
> some
> > > > Regards,
> > > > Robin
<support@>
> wrote:
> > > > > Hi Robin
also do
> > it with
> > > > > Best regards
wrote:
> > > > > > Hi Christian,
I face
> > > is the
> noticed, I
right. Any
> > > > > > suggestions?
> > > > > > Best Regards,
> > > > > > Robin
<support@>
> > > wrote:
> > > > > > > Hi Robin
> > makes the
edited
> file to
> > > > your
> > > > > > > directory)
error at the
> > > 79th
seems
> > > like it
time step.
remind
> > > > you that
> > > > > > > Best regards
<giggsyagami07@>
> > wrote:
> > > > > > > > Hi Christian,
> under the
> > > > folder
> > > > > > > > Thanks. =)
> > > > > > > > Best Regards,
> > > > > > > > Robin
> <support@>
> > > > > wrote:
> > > > > > > > > Hi Robin
like to
> > > see the
> > > > > > > > > model… please?
> > > > > > > > > Best regards
<giggsyagami07@>
> > > > wrote:
> > > > > > > > > > Hi Christian,
> > > > > > > > > > Regards,
> > > > > > > > > > Robin
Support”
> > > <support@>
> > > > > > > wrote:
> > > > > > > > > > > Hi Robin
sounds
> > > like you
> > > > > > > should
havent
> got a
> > > > > > chance to
> > > > > > > > > > > Best regards
> > <giggsyagami07@>
> > > > > > wrote:
> > > > > > > > > > > > Hi Christian,
question.
> > > > > > > > > > > > #include
the
> model,
> > > > and I
> > > > > > > > > could set
changed the
> > > > model to
> > > > > > > > one with
> > > > > > > > > > > > muscles, using
> > > > > > > > > > > > #include
and
> gave a
> > > > total
> > > > > > > > > kinematic
> > > > > > > > > > > > Why is this so?
> > > > > > > > > > > > Best Regards,
> > > > > > > > > > > > Robin
