Spine Model
Hi to all,
I am new to AnyBody.Can any body guide me how to make a Main file from our
existing file Spine.root.any in Repository6.1.I mean i want to load the spine of
anybody in anyscript.
waiting for your kind reply.
regards to all
Check out the hottest 2008 models today at Yahoo! Autos.
Hi Natiq
Welcome to the group!
The fastest way to do this will be to base the model on an existing
application in the ARep part of the repository. There are currently
no models here that make use of only the spine model, they all have
either legs or arms attached.
I would reccommend to start out with the FreePostureModel, this is a
full body model which posture can be controlled by angles set in the
file “Mannequin.any”.
You can modify this model from being a fullbody model to a model of
the spine in the following way.
  1. In the FreePosture.mmain.any file find the line
    #include “…\BRep\Aalborg\BodyModels\FullBodyModel\BodyModel_
    NoMuscles.any” In the main file FreePosture.Main.any”
replace it by
#include “…\BRep\Aalborg\BodyModels\Spine\BodyModel.any”
This will include the spine model instead of the fullbody model
  1. In the “JointAndDriver.any” file remove all drivers related to
    arms and legs also the load folder in the bottom of the file.
This should create a spine model…
Please ask again if you have further questions
— In anyscript@yahoogroups.com, Natiq Hussain <natiqpervaiz@…>
wrote:
> Hi to all,
file from our existing file Spine.root.any in Repository6.1.I mean i
want to load the spine of anybody in anyscript.
> regards to all
Hi soren;
Thaks a lot for your qucik response.
I have still in my model rib cage and head, How i can remove them and
have just spine model?
with regards.
wrote:
> Hi Natiq
a
the
> “#include “…\BRep\Aalborg\BodyModels\FullBodyModel\BodyModel
_
> replace it by
> 2. In the “JointAndDriver.any” file remove all drivers related to
> Best regards
> — In anyscript@yahoogroups.com, Natiq Hussain <natiqpervaiz@>
> wrote:
> > Hi to all,
i
> > regards to all
Hi Natiq
This can only be done by doing modifications to the Brep part of the
repository. I would not recommend doing this as the first step.
The ribcage is one stiff segment removing the rib cage (Thorax
segment) from the model would have the effect that multiple muscles
in the spine would be missing a segment to attach to. So you would
have to identify and remove each of these muscles manually from the
model to be able to load the model again, after having removed the
thorax segment. Furthermore you would need to makes changes in the
joint.any file to remove the joint bewteen l1 and thorax.
Please explain in more detail why you would like these segments
removed?
— In anyscript@yahoogroups.com, “natiqpervaiz” <natiqpervaiz@…>
wrote:
> Hi soren;
and
> with regards.
> wrote:
> > Hi Natiq
existing
currently
have
is
> a
> the
of
l
> _
> > replace it by
to
> > Best regards
> > wrote:
> > > Hi to all,
mean
> i
> > > regards to all
Hi soren,
The purpose of my study is to make myself familiar with AnyBody and
then make changes in AnyBody Spine model according to our FE Model as
near as possible and then calculate muscle forces for different
situation which are not told to me.
Actually we have an FEM Spine Model and it does not have head on it
as for as rib cage is concerned i dont need to remove,as we have it
also.
so please guide me how to remove head.
with best regards.
wrote:
> Hi Natiq
the
> removed?
> Best regards
> — In anyscript@yahoogroups.com, “natiqpervaiz” <natiqpervaiz@>
> wrote:
> > Hi soren;
> and
> > with regards.
> > wrote:
> > > Hi Natiq
> existing
> currently
> have
> is
> > a
in
> > the
model
> of
> l
> > _
> > > replace it by
> to
> > > Best regards
> > > wrote:
> > > > Hi to all,
Main
> mean
> > i
> > > > regards to all
Hi Natiq
Ok, sounds interesting.
To remove the head from the spine model you need to do the following:
1 find the file brep/aalborg/spine/SegmentsThorax.any
outcomment the skull segment
2 in the file brep/aalborg/spine/JointLumbar.any
remove the NeckJoint and NeckJointReaction
3 in your JointAndDrivers.any remove the driver for the neck joint
i think this will make the model load without the skull.
wrote:
> Hi soren,
and
as
it
it
> also.
> with best regards.
> wrote:
> > Hi Natiq
> the
muscles
would
the
the
the
> > removed?
> > Best regards
> > wrote:
> > > Hi soren;
them
> > and
> > > with regards.
> > > wrote:
> > > > Hi Natiq
> > existing
> > currently
all
> > have
this
> > is
> > > a
set
> in
> > > the
> model
> > of
> > l
> > > _
> > > > replace it by
model
related
> > to
> > > > Best regards
<natiqpervaiz@>
> > > > wrote:
> > > > > Hi to all,
> Main
Repository6.1.I
> > mean
> > > i
> > > > > regards to all
Hi soren,
I again need your help.
I want to scale your Spine model to a scale of e.g (1.2).
I have seen several files with differnt scaling option.
what is the best for me?
with best regards.
wrote:
> Hi Natiq
> removed?
> Best regards
> wrote:
> > Hi soren;
> and
> > with regards.
> > wrote:
> > > Hi Natiq
> existing
> currently
> have
> is
> > a
> > the
> of
> l
> > _
> > > replace it by
> to
> > > Best regards
> > > wrote:
> > > > Hi to all,
> mean
> > i
> > > > regards to all
Hi Natiq
I would choose the “LenghtMassFat” scaling, this is the one which will
normally give the best results. This law takes as the name suggests bone
length, bone mass and fat percentage into account.
For details about the scaling laws you can see
http://www.anybody.aau.dk/pdf/ScalingAbstract.pdf
and
http://www.anybody.aau.dk/pdf/ScalingPoster.pdf
Of natiqpervaiz
Sent: 12 November 2007 19:08
Subject: [AnyScript] Re: Spine Model
Hi soren,
with best regards.
wrote:
> Hi Natiq
> removed?
> Best regards
> wrote:
> > Hi soren;
> and
> > with regards.
> > wrote:
> > > Hi Natiq
> existing
> currently
> have
> is
> > a
> > the
> of
> l
> > _
> > > replace it by
> to
> > > Best regards
> > > wrote:
> > > > Hi to all,
> mean
> > i
> > > > regards to all
Hi Soren,
Thanks for your kind response.
Actually we are intersted in just Lubmer spine because our FE Lubmer
spine model has a height 158mm(the distance b/w nucleous of L1 and S1).
I wanted to scale AnyBody Stading Model so that i get the same of
height Luber spine and rest of the body should also be scaled
proportionly.
What you have told me it requires the Body mass and Height.
But i dont have Body Mass because we have just Spine model.
Please guide me.
Natiq
> Hi Natiq
> and
> Best regards
> _____
On Behalf
> Of natiqpervaiz
> Hi soren,
> with best regards.
> wrote:
> > Hi Natiq
> > removed?
> > Best regards
ps.com,
> > wrote:
> > > Hi soren;
> > and
> > > with regards.
ps.com,
> > > wrote:
> > > > Hi Natiq
> > existing
> > currently
> > have
> > is
> > > a
> > > the
> > of
> > l
> > > _
> > > > replace it by
> > to
> > > > Best regards
> > > > wrote:
> > > > > Hi to all,
> > mean
> > > i
> > > > > regards to all
Hi Natiq
If you are missing info about mass and height you will need to use the
UniformScaling instead I guess this law will scale the segments equally in
all directions to obtain the proper segment lengths.
For an example on a model using a scaling file please see the Gait3D model,
and have a look in the AnyMan.any file, this is where the different segment
lengths are defined.
Of natiqpervaiz
Sent: 13 November 2007 12:48
Hi Soren,
proportionly.
Please guide me.
Natiq
> Hi Natiq
> http://www.anybody. <http://www.anybody.aau.dk/pdf/ScalingAbstract.pdf>
> and
> http://www.anybody. <http://www.anybody.aau.dk/pdf/ScalingPoster.pdf>
> Best regards
> _____
On Behalf
> Of natiqpervaiz
> Hi soren,
> with best regards.
> wrote:
> > Hi Natiq
> > removed?
> > Best regards
ps.com,
> > wrote:
> > > Hi soren;
> > and
> > > with regards.
ps.com,
> > > wrote:
> > > > Hi Natiq
> > existing
> > currently
> > have
> > is
> > > a
> > > the
> > of
> > l
> > > _
> > > > replace it by
> > to
> > > > Best regards
> > > > wrote:
> > > > > Hi to all,
> > mean
> > > i
> > > > > regards to all
Hi Soren,
I am trying to see the Psoas Major muscles but they are not being executed
although everything seems to be ok.
Can you please check in stading model or free psoture model?
I checked the Muscle executing file is same like other muscles file.
thanks in advance.
Natiq
Get easy, one-click access to your favorites. Make Yahoo! your homepage.
Hi Natiq
I have just tried the FreePosture model and it did give an activity in at
least one of the psoas major muscle elements.
It could be that for some postures and loading it will have no activity, it
will be different from case to case. So I do not think there is anything
wrong with the definition of this muscle.
Please ask again if you have further questions.
Of Natiq Hussain
Sent: 27 November 2007 12:27
Subject: [AnyScript] Spine Model
Hi Soren,
thanks in advance.
Natiq
Hi Soren,
I agree with you that these muscles give muscle activity and also
muscles forces also.But i just want to see them phyiscally because all
other muscle are phyiscally visibe when we load the model except Psoas
Major.
thanks for qucik response.
Natiq
wrote:
> Hi Natiq
in at
activity, it
> Best regards
> _____
On Behalf
> Of Natiq Hussain
> Hi Soren,
executed
> thanks in advance.
> Natiq
Hi Natiq
I have checked the definition of the psoasmuscles please see for example
BRep/aalborg/Spine/PsoasMajorLeft.any.
Please see a line like
AnyDrawMuscle DrwMus = {#include “…/drawSettings/MusDrawSettings.any”};
If you double click the line you will see that the draw settings for these
muscles are the same as for all other muscles, namely the ones set in the
DrawSettings.any file in the application. This means that the visualization
of these muscles is done with the same settings as all other muscles in the
model.
You can play around with the settings in the Muscle folder in the
DrawSettings.any file this will let you see the muscles in different ways;
these changes will affect all muscles in the model.
Please ask again, if this does not solve the problem
Of natiqpervaiz
Sent: 27 November 2007 14:53
Hi Soren,
Major.
Natiq
wrote:
> Hi Natiq
in at
activity, it
> Best regards
> _____
On Behalf
> Of Natiq Hussain
> Hi Soren,
executed
> thanks in advance.
> Natiq
Dear Soren,
I have tried all your suggestions but nun of them works.
Please take a look.
with best regards.
Natiq
> Hi Natiq
these
in the
visualization
in the
> model.
ways;
> Best regards
> _____
On Behalf
> Of natiqpervaiz
> Hi Soren,
> Major.
> Natiq
> wrote:
> > Hi Natiq
> in at
> activity, it
anything
> > Best regards
> > _____
> On Behalf
> > Of Natiq Hussain
> > Hi Soren,
> executed
> > thanks in advance.
> > Natiq
homepage.
Hi Natiq
I tried to run the FreePostureMove model with this body model
   #include
“…\BRep\Aalborg\BodyModels\FullBodyModel\BodyModel.any”
instead of the default one which is
   // #include
“…\BRep\Aalborg\BodyModels\FullBodyModel\BodyModel_NoMuscles.any”
When I did this, there was a clear bulging of some of the Psoasmajor
muscles.
Please write again if this does not solve the problem.
Of natiqpervaiz
Sent: 28 November 2007 14:41
Dear Soren,
Please take a look.
with best regards.
Natiq
> Hi Natiq
these
in the
visualization
in the
> model.
ways;
> Best regards
> _____
On Behalf
> Of natiqpervaiz
> Hi Soren,
> Major.
> Natiq
> wrote:
> > Hi Natiq
> in at
> activity, it
anything
> > Best regards
> > _____
> On Behalf
> > Of Natiq Hussain
> > Hi Soren,
> executed
> > thanks in advance.
> > Natiq
homepage.
Dear Soren,
I also checked with the model you told but when i run it the result is
same,No Psoas Major muscles.Are you using the Repository 6.1 or some
one else?
Please take a look of PM muscles in the following paper.
http://www.ime.auc.dk/~mdz/pdf/DeZee_et_al_zaragoza.pdf
with best regards.
Natiq
> Hi Natiq
> #include
> // #include
> muscles.
> Best regards
> Søren
> _____
On Behalf
> Of natiqpervaiz
> Dear Soren,
> Please take a look.
> with best regards.
> Natiq
> “AnyBody Support” <support@> wrote:
> > Hi Natiq
example
> these
> in the
> visualization
> in the
> > model.
> ways;
> > Best regards
> > _____
> On Behalf
> > Of natiqpervaiz
> > Hi Soren,
> > Major.
> > Natiq
ps.com,
> > wrote:
> > > Hi Natiq
> > in at
> > activity, it
> anything
> > > Best regards
> > > _____
ps.com
ps.com]
> > On Behalf
> > > Of Natiq Hussain
> > > Hi Soren,
> > executed
> > > thanks in advance.
> > > Natiq
> homepage.
Hi Natiq
I think i may have misunderstood the problem?
I thought that you was looking for muscle bulging and color change due to
activity, but now I realize that your problem is that you may not see the
Psoas muscle at all?
Looking at the article you listed, figure 10 displays the psoas major
muscle. When running a fullbody model the muscle will not look exactly like
fig. 10. , it will insert on the thigh instead of the pelvis, so maybe this
can create a misunderstanding?
Please also see
http://www.rad.washington.edu/atlas2/iliopsoas.html
If this is not the case, please dump a picture of the model, it will help
solve the problem.
I was using rep. 6.1, but it should not matter it should be present in all
repositories.
Of natiqpervaiz
Sent: 30 November 2007 09:42
Dear Soren,
one else?
http://www.ime. <http://www.ime.auc.dk/~mdz/pdf/DeZee_et_al_zaragoza.pdf>
with best regards.
Natiq
> Hi Natiq
> #include
> // #include
> muscles.
> Best regards
> Søren
> _____
On Behalf
> Of natiqpervaiz
> Dear Soren,
> Please take a look.
> with best regards.
> Natiq
> > Hi Natiq
example
> these
> in the
> visualization
> in the
> > model.
> ways;
> > Best regards
> > _____
> On Behalf
> > Of natiqpervaiz
> > Hi Soren,
> > Major.
> > Natiq
ps.com,
> > wrote:
> > > Hi Natiq
> > in at
> > activity, it
> anything
> > > Best regards
> > > _____
ps.com
ps.com]
> > On Behalf
> > > Of Natiq Hussain
> > > Hi Soren,
> > executed
> > > thanks in advance.
> > > Natiq
> homepage.
Dear Soren,
Yes,you have now understood the problem.
Even if they are inserted on thigh why they are not visible?
Actually i just want them to see physicially.
with best regards.
Natiq
> Hi Natiq
due to
see the
exactly like
maybe this
> Please also see
help
> solve the problem.
in all
> repositories.
> Best regards
> _____
On Behalf
> Of natiqpervaiz
> Dear Soren,
> one else?
> http://www.ime.
> with best regards.
> Natiq
> > Hi Natiq
> > #include
> > // #include
> > muscles.
> > Best regards
> > Søren
> > _____
> On Behalf
> > Of natiqpervaiz
> > Dear Soren,
> > Please take a look.
> > with best regards.
> > Natiq
ps.com,
> > > Hi Natiq
> example
> > these
> > in the
> > visualization
> > in the
> > > model.
> > ways;
> > > Best regards
> > > _____
ps.com
ps.com]
> > On Behalf
> > > Of natiqpervaiz
> > > Hi Soren,
because all
Psoas
> > > Major.
> > > Natiq
> ps.com,
> > > wrote:
> > > > Hi Natiq
activity
> > > in at
> > > activity, it
> > anything
> > > > Best regards
> > > > _____
> ps.com
> ps.com]
> > > On Behalf
> > > > Of Natiq Hussain
ps.com
> > > > Hi Soren,
> > > executed
file.
> > > > thanks in advance.
> > > > Natiq
> > homepage.
Dear Natiq
Please create a screen dump of the pelvis region where the Psoas muscle
should have been visible and upload it to the file section of the group.
This will make it easier for me to help you.
Please also state which model the picture is created with.
Of natiqpervaiz
Sent: 03 December 2007 11:38
Dear Soren,
with best regards.
Natiq
> Hi Natiq
due to
see the
exactly like
maybe this
> Please also see
> http://www.rad. <http://www.rad.washington.edu/atlas2/iliopsoas.html>
help
> solve the problem.
in all
> repositories.
> Best regards
> _____
On Behalf
> Of natiqpervaiz
> Dear Soren,
> one else?
> http://www.ime.
<http://www.ime. <http://www.ime.auc.dk/~mdz/pdf/DeZee_et_al_zaragoza.pdf>
> with best regards.
> Natiq
> > Hi Natiq
> > #include
> > // #include
> > muscles.
> > Best regards
> > Søren
> > _____
> On Behalf
> > Of natiqpervaiz
> > Dear Soren,
> > Please take a look.
> > with best regards.
> > Natiq
ps.com,
> > > Hi Natiq
> example
> > these
> > in the
> > visualization
> > in the
> > > model.
> > ways;
> > > Best regards
> > > _____
ps.com
ps.com]
> > On Behalf
> > > Of natiqpervaiz
> > > Hi Soren,
because all
Psoas
> > > Major.
> > > Natiq
> ps.com,
> > > wrote:
> > > > Hi Natiq
activity
> > > in at
> > > activity, it
> > anything
> > > > Best regards
> > > > _____
> ps.com
> ps.com]
> > > On Behalf
> > > > Of Natiq Hussain
ps.com
> > > > Hi Soren,
> > > executed
file.
> > > > thanks in advance.
> > > > Natiq
> > homepage.
