Hello AnyBody,
I am trying to understand how FDK feature is added in SpineFixationWithForceDependentKinematics Model(AMMR1.6.3). I read the following example in tutoral:
AnyRevoluteJoint KneeJoint = {
AnyRefFrame &Shank = .Shank.KneeCenter;
AnyRefFrame &Thigh = .Thigh.KneeCenter;
// Prepare the joint for FDK: Define the reaction types in x and y
// directions to be FDK-dependent. These reaction forces must then
// be switched off and provided by some elastic element that we
// define explicitly below.
Constraints = {
CType = {ForceDep, ForceDep, Hard, Hard, Hard};
Reaction.Type={Off,Off,On,On,On};
// Define springs in the knee, simulating the effect of cartilage
// and ligaments.
AnyForce KneeStiffness = {
AnyKinLinear &lin = Main.MyModel.KneeJoint.Linear;
F = {-1000lin.Pos[0], -5000lin.Pos[1], 0};
However, I am trying to find the translational stiffness defined in SpineFixation model. I cannot find them. What I can find is the following codes:
// define joints, which have force-dependent behaviour
AnySphericalJoint &jntt12l1 = .refJoints.T12L1Jnt;
AnySphericalJoint &jnt12 = .refJoints.L1L2Jnt;
AnySphericalJoint &jnt23 = .refJoints.L2L3Jnt;
AnySphericalJoint &jnt34 = .refJoints.L3L4Jnt;
AnySphericalJoint &jnt45 = .refJoints.L4L5Jnt;
//AnySphericalJoint &jnt5sacrum = .refJoints.L5SacrumJnt; // this joint is commented to avoid over-constrained situation
// constraints type has to be set ForceDep for the force-dependent
// degrees of freedom of the joint
CType = {
ForceDep, ForceDep,ForceDep,
//ForceDep, ForceDep,ForceDep // commented joint
Reaction.Type = {
Off,Off,Off,
Off,Off,Off,
Off,Off,Off,
Off,Off,Off,
Off,Off,Off
//Off,Off,Off // commented joint
So I have one questions. 1. the FDK feature defined in SpineFixation model is for 3 ration dofs or 3 translational dofs ? 2. If it is translational FDK feature, where I can check stiffness?
Amin
