Summary of AnyMechOutputFileForceExport
the AnyMechOutputFileForceExport is very helpful but it possibly exports quite a lot of output forces. Is it possible to summarize them automatically to one force and one moment per segment?
This job could of course been done manually, but the summary depends on the attached muscles which may be extended or changed. This again would necessitate changing the summarizing job.
Thom
You can use the AnyForceMomentMeasure2 class to sum up all forces and moments acting in one point. This gives you basically a free body diagram on a specified point.
The intention behind the AnyMechOutputFileForceExport class is to give the whole, complex loading conditions on a segment for FEA.
