The direction of the output data
Hi everybody
I’m analyzing the output data of knee joint force and moment,
and I have some questions.
The positive direction of “AxialMoment” data is means the exteral axial moment?
The positive direction of “LateralMoment” data is means the varus applied moment?
The positive direction of “MedioLateralForce” data is means the lateral Force?
The positive direction of “AnteroPosteriorForce” data is means the force from the anterior direction? Is force is accroding to the global or relative coordinates?
Thanks
All those joint reaction forces are given in local coordinate system. For example look at the file RightLegNoMusclesSelctedOutput.any in the folder Body/AAUHuman/LegTD. You will find the list of the forces with the reference frame and the positive direction for each one.
Best regards, Sylvain.
