Thanks for the reply,
I’ve managed to successfully analyse several trials, however some fail during the Kinematic analysis.
For example:
Failed to resolve kinematic constraints. Newton relaxation too small. (final kin. error = 9.079811E-002)
Constraint no. 77 above error tolerance 0.001000, error = 0.014175.
Constraint no. 78 above error tolerance 0.001000, error = 0.008129.
Constraint no. 79 above error tolerance 0.001000, error = 0.002424.
Constraint no. 81 above error tolerance 0.001000, error = 0.001572.
Constraint no. 82 above error tolerance 0.001000, error = 0.014438.
Constraint no. 83 above error tolerance 0.001000, error = 0.011689.
Constraint no. 84 above error tolerance 0.001000, error = 0.001940.
Constraint no. 85 above error tolerance 0.001000, error = 0.003196.
Constraint no. 86 above error tolerance 0.001000, error = 0.001440.
Constraint no. 88 above error tolerance 0.001000, error = 0.001344.
Constraint no. 91 above error tolerance 0.001000, error = 0.001155.
Constraint no. 92 above error tolerance 0.001000, error = 0.001226.
Constraint no. 93 above error tolerance 0.001000, error = 0.001057.
Constraint no. 94 above error tolerance 0.001000, error = 0.003405.
Constraint no. 95 above error tolerance 0.001000, error = 0.005300.
Constraint no. 96 above error tolerance 0.001000, error = 0.002579.
Constraint no. 97 above error tolerance 0.001000, error = 0.002013.
Constraint no. 119 above error tolerance 0.001000, error = 0.006384.
Constraint no. 121 above error tolerance 0.001000, error = 0.004655.
Constraint no. 201 above error tolerance 0.001000, error = 0.005854.
Constraint no. 202 above error tolerance 0.001000, error = 0.001094.
Constraint no. 203 above error tolerance 0.001000, error = 0.001044.
Constraint no. 219 above error tolerance 0.001000, error = 0.004382.
Constraint no. 220 above error tolerance 0.001000, error = 0.001134.
Constraint no. 221 above error tolerance 0.001000, error = 0.007065.
Constraint no. 222 above error tolerance 0.001000, error = 0.024995.
Constraint no. 224 above error tolerance 0.001000, error = 0.001706.
Constraint no. 226 above error tolerance 0.001000, error = 0.001753.
Constraint no. 227 above error tolerance 0.001000, error = 0.007458.
Constraint no. 228 above error tolerance 0.001000, error = 0.003358.
Constraint no. 238 above error tolerance 0.001000, error = 0.001238.
Constraint no. 282 above error tolerance 0.001000, error = 0.088704.
Constraint no. 283 above error tolerance 0.001000, error = 0.003134.
Constraint no. 284 above error tolerance 0.001000, error = 0.090798.
Constraint no. 287 above error tolerance 0.001000, error = 0.003215.
Constraint no. 288 above error tolerance 0.001000, error = 0.001515.
Constraint no. 289 above error tolerance 0.001000, error = 0.001515.
Constraint no. 292 above error tolerance 0.001000, error = 0.001515.
Constraint no. #0 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Mus.ArtificialRake.LinCombDrv’ above error tolerance 0.001000, error = 0.005854.
Constraint no. #1 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Mus.ArtificialRake.LinCombDrv’ above error tolerance 0.001000, error = 0.001094.
Constraint no. #2 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Mus.ArtificialRake.LinCombDrv’ above error tolerance 0.001000, error = 0.001044.
Constraint no. #0 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Jnt.FE.Constraints’ above error tolerance 0.001000, error = 0.004382.
Constraint no. #1 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Jnt.FE.Constraints’ above error tolerance 0.001000, error = 0.001134.
Constraint no. #2 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Jnt.FE.Constraints’ above error tolerance 0.001000, error = 0.007065.
Constraint no. #3 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Jnt.FE.Constraints’ above error tolerance 0.001000, error = 0.024995.
Constraint no. #0 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Jnt.PSProximalConstraints’ above error tolerance 0.001000, error = 0.001706.
Constraint no. #2 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Jnt.PSProximalConstraints’ above error tolerance 0.001000, error = 0.001753.
Constraint no. #0 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Jnt.PSLinDistalConstraint’ above error tolerance 0.001000, error = 0.007458.
Constraint no. #1 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Jnt.PSLinDistalConstraint’ above error tolerance 0.001000, error = 0.003358.
Constraint no. #4 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.ShoulderArm.Jnt.WristJointDeviation.Constraints’ above error tolerance 0.001000, error = 0.001238.
0.57) …Kinematic analysis terminated
ERROR(OBJ.MCH.KIN3) : C:/D…s/h…s/A…a/A…y/A…x/A…3/A…n/E…s/C…3/GaitFullBody.main.any : KinematicStudyForParameterIdentification.Kinematics : Kinematic analysis failed in time step 57
I’ve checked the markers etc, No Drop-outs, No sudden impossible marker positions etc, I’ve added a filter and weightfunction to exclude drop-outs, but still no luck…
Could you please explain to me what this error means?
Is the model having problems while fitting to the marker positions?
Greetings,
Hans
