using Joint Angle data as input
Good morning.
I am making a motion using machine learning, and try to do Inverse Dynamics by Anybody.
Therefore, it is decided by Joint Angle data, not C3D data(such as trc or mot file).
I wonder if there is any model in AnyBody that can create motion using Joint Angle data.
I tried it by modifying the file “FullBody- (c3d file name) -euler- (body) .txt” of the Mocap model, but there is a lot of noise.
Do I have to set up a Driver for every joint?
Thank you.
It should be possible to use the model you have tried with for this purpose.
It is a model driven only by angular data extracted using markers.
I did not understand the noise issue, if it from the input data right?
If so please be aware that is not without problems to apply filters on the angular data, i would first convert the data using no filters to virtual markers and then apply filters.
