Dear Sir
When I am loading
MOCAP-driven Gait Models (C3D input): Full body or lower extremity gait model based MOCAP data. The model uses the redundant kinematic solver. It is a good starting point for understanding and making MOCAP driven models. The MOCAP data is imported directly from a C3D file.
Files: MoCap_FullBody.main.any,
with reference added & AnyMechOutputFileForceExport FE_out added the program becomes like this given below
#include “…/libdef.any”
// Switch to use the detail neck model
#define UseDetailNeckModel 0
// Switch to include Arms
#define UseUpperExtremities 1
// Prefix for the output file names
// to distinguish the full body and the lower body models
#define OutputFileNamePrefix “FullBody-”
// Switch to save all results in output folder
#ifndef AutoSaveOption
#define AutoSaveOption 0
#endif
// Detailed description can be found at:
#include “Model/Description.any”
//Set this to 1 if you want to run the motion and Parameter Optimization identification
#ifndef MotionAndParameterOptimizationModel
#define MotionAndParameterOptimizationModel 0
#endif
//Set this to 1 if you want to run the inverse dynamic analysis
#ifndef InverseDynamicModel
#define InverseDynamicModel 1
#endif
//Usually only have one of the two switches active so set the inactive analysis to 0
// Following will include several predefined classes to generate markers and environments
// Usually, there is no need to make changes in this file:
#include “Model/Classes.any”
Main = {
// This file controls most of the Settings of your Model, the following items are defined here:
// 1. Marker Names
// 2. Marker locations
#include “Model/ModelSetup.any”
// Define the Environment around the human
#include “Model/Environment.any”
// This file controls most of the Trial Specific setup, the following items are defined here:
// 1. C3D file Name
// 2. Start and End Frame
// 3. Subject Anthropometric data
// 4. Initial guess on position
// If you want to run the model on your own data this is the place to start:
#include “Input/TrialSpecificData.any”
AnyFolder Studies ={
// Usually, there is no need to make changes in the following files. PLease be aware. that
// changes in the Kinematics and InverseDynamics may lead to model failure and/or unrealistic results:
#if MotionAndParameterOptimizationModel
#include “Model/Kinematics.any”
#endif
#if InverseDynamicModel
#include "Model/InverseDynamics.any"
#endif
FileName = “Output highload.xml”;
UseRefFrameOnOff = On;
AnyRefFrame & ref1 = Main.Studies.HumanModel.BodyModel.Right.Leg.Seg.Thigh;
XMLformatOnOff = On;
AnySeg &thigh = Main.Studies.HumanModel.BodyModel.Right.Leg.Seg.Thigh;
AnyOperationShellExec ConvertToAbq={
Show=On;
FileName = "Output\AnyFE2Abq\AnyFE2Abq.exe";
Arguments = "-i .\Output highload.xml -o .\Output\output.inp -m .\Output\implant.inp";
WorkDir=".\ ";
}; //Main
[b]But I am not getting the muscle load file of .xml format
please help me to solve this problem,
its extremely urgent[/b]
Thanks & regards
Mithun
