Working with inertial sensors
I’m working with inertial sensors which give just rotation and velocities of segments as Euler or Cartesian coordinate. What I found out from your software is that it is programmed to be compatible with optoelectric sensors which can export position of sensors in 3D. Inertial sensors can not find position of segments and they just work with rotations.
Is there any way to import output data of these sensors in your software? I mean that I define which joints are my markers and then give my database of rotations of markers to the software.
I would be very grateful if you can help me.
Mohamad
Hi Mohamad,
Yes, you can drive the model by using individual joint angles. You may want to have all segmental lengths though to make the model correspond to your experiment.
P.S. This is a wrong forum branch (intended for debugging models, not general questions). Please do not post in this thread and try to use more relevant sections.
