Workspace loading error
Dear Sir/Madam
I’ve error at loading Workspace loading as following
Could you let me know what was my problem ?
Thank you
Seungkook Jun
Loading Settings Script from : 'C:\Users\SK\AppData\Local\AnyBody Technology\AnyBody.5.x.x\Settings.anyst
Settings Loaded
------------------------------------------------ Loading Workspace Script from : 'C:\Users\SK\AppData\Roaming\AnyBody Technology\AnyBody.5.x.x\AMMRV1.4\Application\Examples\GaitFullBody_SK\WS_SK17.anyws ------------------------------------------------
ERROR(SCR.EXP1) : C:\Users\SK\AppData\Roaming\AnyBody Technology\AnyBody.5.x.x\AMMRV1.4\Application\Examples\GaitFullBody_SK\WS_SK17.anyws(327) : ‘=’ : Illegal operation for given argument types : ‘AnyFloat[3]’ ‘=’ ‘AnyInt[3][3]’
--------------------------------------------------------- Workspace invalid - closing -------------------------------------------------------------------------------
Hi seungkook,
I am not really sure what causes this, could you provide more details on how you created this error.
[ol]
[li]Which AMS version are you using?[/li][li]Did you save and load the workspace using the same version?[/li][li]Which type of windows did you have open when you saved the workspace?[/li][li]Please upload the model if possible[/li][/ol]Best regards
Dear Søren
Thank you for your reply.
  1. My AMS version is
    AnyBody version : 5. 2. 0. 3070
    Build : 15484.49920
    Faculty Research License
    Licensed to : 1044.1.2 State University of New York at Buffalo
    Expiration : permanent
  2. Yes, I saved and loaded the worksapce using the same version
  3. I am using Windows 7 Enterprise 64bit
  4. I used GaitFullBody.main.any in AMS and did not changed model
I did try save workspace with same model but difference C3D file but never succeeded.
Thank you
Seungkook Jun
Dear Seungkook Jun,
Thanks for the detailed info.
We have tried replicating your problem in AMS 5.2 using the same model but we have not been able to do this yet.
Could you explain in steps what you did?
Which windows did you have open in AMS: AnyChart etc...?
I did not understand this line:
Dear Søren
What I did in detail is following.
  1. load ‘GaitFullBody.main.any’
  2. Change C3D file name in “TrialSpecificData.any”
  3. change force plate setting in ‘ForcePlateType2AutoDetection.any’
  4. Do Parameter optimization by changing
    #define MotionAndParameterOptimizationModel 1
    #define InverseDynamicModel 0
  5. Do inverse dynamic analysis by changing
    #define MotionAndParameterOptimizationModel 0
    #define InverseDynamicModel 1
  6. Check result from ‘Anychart2D/3D’
  7. Close ‘Model view’ and ‘Anychart2D/3D’ windows
  8. Save workspace from file menu
  9. close AMS
  10. Run AMS
  11. Open the workspace
    12 Run ‘Reply’
    13 Then I’ve got a message as following
    Settings Loaded
    ------------------------------------------------ Loading Workspace Script from : 'C:\Users\SK\AppData\Roaming\AnyBody Technology\AnyBody.5.x.x\AMMRV1.4\Application\Examples\GaitFullBody_XB09\WS_XB09.anyws ------------------------------------------------
    ------------------------------------------------ Workspace loaded -------------------------------------------------------------------
    Loading Main : “C:\Users\SK\AppData\Roaming\AnyBody Technology\AnyBody.5.x.x\AMMRV1.4\Application\Examples\GaitFullBody_XB09\GaitFullBody.main.any”
    Scanning…
    Parsing…
    Constructing model tree…
    Linking identifiers…
    Evaluating constants…
    Configuring model…
    Evaluating model…
    Loaded successfully.
    Elapsed Time : 8.509000
    ERROR(OBJ.OperationReplay1) : C:/U…s/SK/A…a/R…g/A…y/A…x/A…4/A…n/E…s/G…9/GaitFullBody.main.any : InverseDynamicStudy.Replay : Replaying data failed in time step 0. Data is not ready.
thus I have to run inverse dynamic analysis whenever I need to check some results.
Thank you.
SK
Dear Seungkook Jun,
Saving the workspace will save the layout of the windows not the result. The results can be saved in another way, but not very many users seems to be aware of it :wink: please see here:
http://wiki.anyscript.org/index.php/All_about_AnyBody_Modeling_System#Save_Load_and_Replay_Results
