.xml file
I am trying to generate the .xml file. i have created the files_in folder in my model folder. i am not sure where i’m going wrong and why i have no .xml file generated.
Hi areddy,
i have taken a quick look at the model, i think the problem is that the "AnyMechOutputFileForceExport " object is not inside the AnyBodyStudy which run the inverse dynamic analysis.
You can fix it in two ways:
1: move the object inside the study
2: make a reference in the study to this object
