I've been looking around the forum for similar situations, I've been making some changes to the ground reaction forces and the muscle recruitment criteria, but still the error continues.
It looks like your model is in contact with the ground at the feet, knees and the hands but only contact with the feet is simulated. If this is the case, you will need to add some contact model between the ground and the knees and the ground and the hand. Otherwise, it is not possible for the solver find a solution.
There are different ways in which you can add this to your model. For example, you could adapt the code for GRF prediction, or you can look at Seated Human Model in the AMMR.
