Hi everyone,
I decided to update to the last AMMR v2.1.0 for performing gait motion analysis with my own C3D files in the best conditions.
I can’t find anymore the AnyGait model is used to work on ?
I assume I should from now on use the Plug-in-gait_Simple model under MocapExamples folder, correct ?
If so, after replacing the TrialFileName and loading the model, I obtain the following error message:
[SIZE=1]ERROR(SCR.EXP1)[/SIZE] : [SIZE=1]C:/U…s/p…i/D…s/A…x/A…o/A…n/M…s/P…e/S…p/ForcePlates.any(16)[/SIZE] : Defined at : [SIZE=1]C:/U…s/p…i/D…s/A…x/A…o/T…s/A…p/F…s/ForcePlateAutoDetection.any(35)[/SIZE] : Operator ‘=’ : Illegal operation for given argument types : ‘AnyEnum’ ‘=’ ‘AnyInt[1]’. Allowed values : Off, On
I keep looking but I can’t find the solution …
Is it coming from my C3D file having only one force plate ?
With the foot pressing on ithis force plate at the second step and not the first one ?
Thank you in advance for your precious help,
