thanks. From your reply I knew that I would learn anybody quickly with your
help.
I copyed the program to the blow. when I run it, the system told me that :
“Move_plate.Data”-the matrix must contain the same number of columns as T has
elements.
Acturally, I had did it I think. And what is thedata of the class
“AnyKinEqInterPolDriver” format? I want to know clearly
AnyBody Support <support@anybodytech.com>
Hi Alec
Welcome to the group
Here is a small example from the top of my head…
AnyPrismaticJoint jnt =
Axis = z;
AnyRefFrame &<Insert name0> = …node1?;
AnyRefFrame &<Insert name1> = …node2?;
AnyKinEqInterPolDriver interpolationdriver =
Type = bSpline;
BsplineOrder = 4;
T = {0,1,2,3,4}; //time vector from 0 to 4 sec
Data = {{0,1,2,3},{0,1,2,3}}; //example of data
//FileName = “”; //you can also use a file instead of the two
lines above!!
AnyKinMeasure &ref = .jnt; //reference to the joint above…
}; //end interpoldriver
As you might know there are a number of tutorials available on the
web, see for example http://www.anybodytech.com/701.0.html
they might be helpful…
Please ask again if you have further questions.
— In anyscript@yahoogroups.com, “yueningma” <yueningma@…> wrote:
> hello everyone.
> I am doing a project recently. And I want to know how to use the
class
> “AnyKinEqInterPolDriver” to drive the Prismatic joint with data
> wishing every one a good day.
> waiting your reply everytime.
> alec
> 4 Oct 2007
@yahoo.cn
