when using AB 5.2 with AMMRV1.5, after having performed the InverseDynamics analysis: When i double click
Main.HumanModel.BodyModel.SelectedOutput.Trunk.Muscles.Envelope
AB always crashes.
I asked around and nobody knows of an issue there. We also made quick tests in some models using AMS v5.2, 5.2.1, 5.3 and 5.3.1 and we could not reproduce the crash.
Does this happen also with a “fresh and clean” model from the repository?
“We could find that in the AMS 5.1 version there is a bug in AnySearchFun function in some cases. So now we are working around to fix this problem as soon as possible.”
I would have preferred that i recalled it wrongly ;).
so yes, there was a bug in the AnySearchFun, however, that was fixed Feb/Mar2012. This was also not related to the trouble you are experiencing now.
Daniel and I run on various different AMS version the StandingMOdel (and some others). When either one of us double clicks on
no crash happens. Do you see any patterns? Is ChartFX and MOdelView always open at the same time?
