You were supposed to export muscle forces in the FE mesh ref. frame. Normally you construct a CT scan ref. frame inside the relevant segment and use this one for export. If you place your CT-based STL in this ref. frame, it should match with the AnyBody bone.
We are using the same bone in both Abaqus and AnyBody so they have the same reference system. We exported the bone from AnyBody as a stl. file and then used it in Abaqus but the forces are as I said before are not aligned....
The 2 bones should be aligned. If they are not - there is mismatch. Secondly, could your mesher somehow displace the mesh or export it in a different ref. frame?
Are you exporting tibia? Then yes. And even in other bones there are some muscle forces are a little away from the surface - they represent via points. Could you post a picture of the problem?
it could be okay, a little difficult to say from this projection. But you could also see what objects these are. Do joint nodes appear to be in the right place? I believe you could also check what forces away from the surface and then find corresponding entities in AnyBody.
Okay, then it is probably okay. The fibula is included into the tibial segment. And the rest of the nodes seem to be matching well. I think the results are as expected.
Are you looking at the load step time in Abaqus? Or actual output in the input files? I would expect everything to be there, but it might differ from the load step time, which is not set by the converter. Could you check this? You can just open generated files and see that the amplitudes are created for the whole analysis.
The time - it probably depends what you try to analyze. Are you interested in peak stresses? Or in average loading over a cycle of motion? I think Abaqus may have an automatic increment decision system depending on the loads and selected parameters.
Try reading Abaqus ref. manuals for the associated keywords?
