Hi Lissette
The abdominal pressure model is rather complicated and difficult to explain in detail.
The best description you will find at this link,
http://www.anybody.aau.dk/repository/Repository5/Repository5_files/frame.htm
please be very patient, the file is rather large, please look at slide 48 and forward.
Basically the abdominal pressure model works like a “mechanical” ballon, the transversus muscles are squeezing it and it can produce an extension moment on the spine. The abdominal pressure muscle will only be active if it of benefit for the other muscles and it is recruited like any other muscle.
The forces you are reporting are some internal quantities that is usually not of interest, basically these values shows how much each of the transversus muscles press against the volume.
I have tried to replicate the numbers you provide but i have not been able to do this. I took the FreePostureMove model from the new AMMRV1 repository excluded the legs and arms, removed gravity, and added muscles in the spine. When running this model i have zero activity and and zero force in the support muscles you list. Could it possibly be that you have been running the model with some motion? this will produce some forces due to centrifugal forces…
Concerning the missing cyl.any file i am afraid that you have tried to run the root file BuckleNoAbdominalPressure.root.any file. This file is a leftover in the repository and should have been removed from the directory earlier. The file relates to very old version of the abdominal model, sorry for this.
It is not so easy to remove the abdominal model because many of the muscles are connected to the buckle and if the abdominal muscle is removed it may lack support and make the solution fail. In the bottom of the Trunk/Buckle.any file you will find the Abdominal muscle and if the strength of this is set to zero it should remove the effect of the abdominal pressure, but the downsize is that it may introduce instability into the solution.
Concerning moving the joints: When you move the sRel values of the joints it will change the kinematics and kinetics of the model so any change in the kinematics will have an influence on the calculated forces, there is no way that this can be avoided.
Hope these answers helps you move on, otherwise please write again.
