Hello, I'm doing the connection between anybody and ABAQUS recently. I output the xml file of writing force and boundary conditions, but failed to use the AnyFEAbq plug-in. I opened it directly AnyFEAbq.exe Then input the path of the XML file and the output path, and the inp file of the finite element model, but failed. I can confirm that the license file is available within the maintenance period. I want to know what's wrong with me in the process? thank!
Hi Yu yue,
What error message do you see? Most likely your path settings are not correctly specified and the converter reports an error. If you cannot see the error because the window closes too fast - try opening and running it from the command line prompt (Windows+R keys, type: cmd).
