hello, every, I have a problem when running the model based “GaitLowerExremity”:
I want to know what should to be done to avoid this erro? and what the problem lies in?
it pointed out like the following:
[LEFT][LEFT]Position analysis failed : 176 independent constraints and 180 unknowns [/LEFT]
[LEFT] - attempts to continue (attempt no. 1)[/LEFT]
[LEFT] - attempts to continue (attempt no. 2)[/LEFT]
[LEFT] - attempts to continue (attempt no. 3)[/LEFT]
[LEFT] - attempts to continue (attempt no. 4)[/LEFT]
[LEFT] - attempts to continue (attempt no. 5)[/LEFT]
[LEFT] - attempts to continue (attempt no. 6)[/LEFT]
[LEFT] - attempts to continue (attempt no. 7)[/LEFT]
[LEFT] - attempts to continue (attempt no. 8)[/LEFT]
[LEFT] - attempts to continue (attempt no. 9)[/LEFT]
[LEFT] - attempts to continue (attempt no. 10)[/LEFT]
[LEFT]Constraint no. #3 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.Leg.Jnt.PatellaFemur.Constraints’ above error tolerance 0.001000, error = 0.004484.[/LEFT]
[LEFT]Constraint no. #4 in ‘Main.Studies.KinematicStudyForParameterIdentification.HumanModel.BodyModel.Right.Leg.Jnt.PatellaFemur.Constraints’ above error tolerance 0.001000, error = 0.005148.[/LEFT]
[LEFT]ERROR(OBJ.MCH.KIN3) : D:/A…3/A…n/E…s/r…y/GaitLowerExtremity.main.any : KinematicStudyForParameterIdentification.InitialConditions : Kinematic analysis failed in time step 0[/LEFT][/LEFT]
Thank you for all your help~
