Hi.
I am a user who is currently using the ground reaction force prediction algorithm(Code) that is opened in Anybody wiki.
I observed residual force by the Code because GRF prediction pattern is different from the experimental results. And the residual force has different pattern from experimental data. (yellow circle)
I didn’t modified the opened code except “GRF_example”.
Are there any adjustable elements for the accuracy of the residual force?(Besides the FootPlateConditionalContact function and subjuct’s weight)
I want to match the part in the yellow circle in the attached picture.
Thank you.
