About L5/S1 Joint moment
Dear AnyBody Team,
I’d like to get L5/S1 joint moments from an AnyBody standing model.
Joint reactions appear to give compressive forces, and there is
Sacrumpelvis reaction folder.
I though that sacrumpelvis reaction may be equivalent to L5/S1 joint
moments, yet values from sacrumpelvis reaction seem to be too small.
Is there a simple way to obtain L5/S1 joint moments?
Sincerely,
Sunwook
Hi Sunwook
I think the joint you are looking for is the L5Sacrum joint in the
model.
You are correct that joint reactions in the spine are the reaction
forces in the three directions, since spherical joints are being used.
If you are looking for the moment, you need to use a model without the
ordinary muscles on. so choos a bodymodel version
names “_NoMuscles.any”. This model have each dof equipped with moment
generating muscles, and you may read out the monments.
The reason why we have a SacrumPelvis reaction is because there are no
muscles to carry this reaction.
Please ask again if you have further questions.
— In anyscript@yahoogroups.com, “ninegu_sun” <ninegu_sun@…> wrote:
> Dear AnyBody Team,
> Sincerely,
> Sunwook
Thank you for the quick response.
I just checked JointMuscles folder to see positive and negative
muscle outputs for L5SacrumJnt, using the No_Muscle model.
The values appear to be still small (-39 Nm is the max value in all
DOFs), while compressive forces fall in a reasonable range.
Currently, I use the SpineTwoArms\BodyModel_NoMuscles.Any and apply
external forces on the hands (measured from loadcells).
Is it possibly because of external loads applied on the hands? I use
the same method for applying forceplate forces in Gait3D to apply
external forces on the hands.
Does this mean that I need to include a seperate folder to compute
L5/S1 moments?
Sincerely,
Sunwook
wrote:
> Hi Sunwook
> model.
used.
the
moment
no
> Best regards
> S?en, AnyBody Support
> — In anyscript@yahoogroups.com, “ninegu_sun” <ninegu_sun@> wrote:
> > Dear AnyBody Team,
model.
joint
small.
> > Sincerely,
> > Sunwook
Hi Sunwook
I am not sure what was the size of you hand load so i can not judge
if the moment of 39Nm is ok or not. If the way you have applied the
forces are correct this moment should be ok, you should not need to
add extra stuff to read out the moment.
To check your model, you could try expluding your hand loads and
just add a AnyForce3D to the hands. This will create a constant
force vector and you will be able to check if the moments of the
joints are resonable. You may exclude gravity to get a more clear
picture if needed.
In principle it should be possible to load the hands in the same way
as the feet in the Gait3D model.
I hope this helps you move on
all
apply
use
> L5/S1 moments?
> Sincerely,
> Sunwook
> wrote:
> > Hi Sunwook
the
> > model.
reaction
> used.
without
> the
> moment
are
> no
> > Best regards
wrote:
> > > Dear AnyBody Team,
> model.
is
> joint
> small.
> > > Sincerely,
> > > Sunwook
Hello Soren,
Thank you for the inputs. As you suggested, I did simple checks.
First, I checked a fixed posture (i.e., 70 degree flexion) without
hand loads. Jointmuscle outputs for the L5/S1 are about 75 Nm. The
values are a bit lower than what I got from 3DSSPP. Yet, they are
acceptable.
Then, I repeated the same model with only one change in the motion
driver. I drove the trunk with measured angles (roughly flexion
angles range from 0 to 70 degree). For simplicity, lateral bending
and axial rotation were set to be 0. Then, Jointmuscle outputs for
the L5/S1 are found to be about 10 Nm.
I applied the same marker dirvers used in Gait3D. So, the reaction
type for marker drivers are set to be “off”.
I am not sure if driving posture with markers could cause this kind
of problem, since it appears that AnyBody gives acceptable values for
the static posture. I think I need more of your advice on this
problem to solve it.
Sincerely,
Sunwook
wrote:
> Hi Sunwook
judge
> picture if needed.
way
> Best regards
> all
> apply
> use
compute
> > L5/S1 moments?
> > Sincerely,
> > Sunwook
> > wrote:
> > > Hi Sunwook
> the
> > > model.
> reaction
being
> > used.
> without
> > the
> > moment
> are
> > no
> > > Best regards
> wrote:
> > > > Dear AnyBody Team,
> > model.
> is
L5/S1
> > joint
> > small.
> > > > Sincerely,
> > > > Sunwook
Hi Sunwook
It sounds as it could be a dynamic issue that kick in here maybee.
To check if this is the case please try to increase the tEnd value
of the analysis so that motion effectively becomes almost static.
The marker drivers should not cause any unloading of the spine
unless some the drivers have the reactions swithed on.
Please write again if this do not clearifies the matter
wrote:
> Hello Soren,
The
> acceptable.
bending
for
reaction
kind
for
> Sincerely,
> Sunwook
> wrote:
> > Hi Sunwook
> judge
the
to
clear
> > picture if needed.
> way
> > Best regards
negative
in
> > all
> > apply
hands? I
> > use
apply
> compute
> > > L5/S1 moments?
> > > Sincerely,
> > > Sunwook
> > > wrote:
> > > > Hi Sunwook
in
> > the
> > > > model.
> > reaction
> being
> > > used.
> > without
> > > the
with
> > > moment
there
> > are
> > > no
> > > > Best regards
> > wrote:
> > > > > Dear AnyBody Team,
standing
> > > model.
there
> > is
> L5/S1
> > > joint
too
> > > small.
> > > > > Sincerely,
> > > > > Sunwook
